This teardown is not a repair guide. To repair your Gas and Smoke Detector, use our service manual.
  1. Smoke Detector Teardown, Smoke Detector Teardown: step 1, image 1 of 2 Smoke Detector Teardown, Smoke Detector Teardown: step 1, image 2 of 2
    • Use a screwdriver to pry open the plastic enclosure. It might be easier to push the buzzer through the hole, if you need extra leverage.
  2. Smoke Detector Teardown: step 2, image 1 of 1
    • The buzzer is unhooked from the PCB board, by hands.
  3. Smoke Detector Teardown: step 3, image 1 of 2 Smoke Detector Teardown: step 3, image 2 of 2
    • This is the circuit for the smoke detector. It is powered by a 9V battery. The 3 metal leafs are contacts for the buzzer and the bigger leaf is for the test button.
  4. Smoke Detector Teardown: step 4, image 1 of 1
    • The metal cap is removed to reveal a, MC145017, driver chip and americium sensor. Do not remove americium from the sensor!
Ari Dubinsky
253 Reputation
1 Guide authored
1 Guide Comment
Thanks bro 👍
BrunostNoodles - Reply Share
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 86
All Time: 9,158
