This teardown is not a repair guide. To repair your Small Digital Camera, use our service manual.
    1. Small Digital Camera Teardown, Small Digital Camera Teardown: step 1, image 1 of 3 Small Digital Camera Teardown, Small Digital Camera Teardown: step 1, image 2 of 3 Small Digital Camera Teardown, Small Digital Camera Teardown: step 1, image 3 of 3
      • This is a digital camera I bought from a thrift store for $10. It has a very small 0.3 megapixel camera sensor and a depressing low resolution screen .
      • The camera is very light, weighing significantly less than an ounce.
      • The battery keeps dying after charging almost instantly, so it is time to put an end to this thing.
      Ask FixBot
    2. Small Digital Camera Teardown: step 2, image 1 of 3 Small Digital Camera Teardown: step 2, image 2 of 3 Small Digital Camera Teardown: step 2, image 3 of 3
      • For Step One, use a Philips screwdriver to remove the 2 screws on the right side of the camera.
      • Once the screws have been removed, use a Flathead screwdriver or an opening pick to unclip the plastic tabs holding the outside case together.
      • Be careful of any ribbon cables that may be under the front plastic case, as a screwdriver or opening pick may damage one of the cables, if any.
      Ask FixBot
    3. Small Digital Camera Teardown: step 3, image 1 of 3 Small Digital Camera Teardown: step 3, image 2 of 3 Small Digital Camera Teardown: step 3, image 3 of 3
      • Once the front plastic case is removed, disconnect the battery.
      • Do not puncture the battery. You will have a hard time with the battery entering thermal runaway, eventually putting out poisonous gasses, and flames…
      • (Please use an opening pick, and not a flathead to pry out the battery. You will be happy…)
      Ask FixBot
    4. Small Digital Camera Teardown: step 4, image 1 of 3 Small Digital Camera Teardown: step 4, image 2 of 3 Small Digital Camera Teardown: step 4, image 3 of 3
      • Unscrew the four screws holding the PCB in place by using a Philips head screwdriver.
      • Use an opening pick or flathead to pry the board out.
      • To get the board out, you must remove the SD card from the card slot. (I already removed it before I even started this teardown.)
      Ask FixBot
    5. Small Digital Camera Teardown: step 5, image 1 of 3 Small Digital Camera Teardown: step 5, image 2 of 3 Small Digital Camera Teardown: step 5, image 3 of 3
      • The PCB is quite uneventful, as only one major chip exists. I can’t find any information on the main chip, but it is a quad-flat package from “JR” integrated circuits.
      • You can remove the screen by un-fastening the clip holding the ribbon cable in place. Just use your finger.
      • Other components on the board include another small IC, a quartz crystal/oscillator, and a couple of capacitors and resistors.
      Ask FixBot
    6. Small Digital Camera Teardown: step 6, image 1 of 3 Small Digital Camera Teardown: step 6, image 2 of 3 Small Digital Camera Teardown: step 6, image 3 of 3
      • Here’s the tiny 0.3 megapixel camera module. This thing’s video and picture quality is very sad, but at least it works…
      • Thank you for your support in viewing this teardown! I hope it was helpful or informatively interesting.
      Ask FixBot
Mr.CircuitBoard
2,404 Reputation
16 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 102
All Time: 539
