This teardown is not a repair guide. To repair your Scanmaker Air, use our service manual.
    1. Scanmaker Air Teardown, Prying open: step 1, image 1 of 1
      • I used flat 2 out of the IFixIt kit I have. Slide it from USB down on both sides of device. Likely could be done better with other tools
      Ask FixBot
    2. Scanmaker Air Teardown, Internal clips: step 2, image 1 of 1
      • Mindful of these. They are thin and could break
      Ask FixBot
    3. Scanmaker Air Teardown, Inside look: step 3, image 1 of 1
      • Left is "front". Right is "back"
      Ask FixBot
    4. Scanmaker Air Teardown, Replacing + putting together: step 4, image 1 of 1
      • I was mostly straight up and down with a slight angle to wiggle the USB port down. Bottom of plastic housing to battery side. I placed the orange tip after. Then snap housing back on. Feel is different but may still work (I tore down 2 that are unknown cause of failures). Make sure orange part is in before placing housing back on
      Ask FixBot
Bookworm 3616
134 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 507
