This teardown is not a repair guide. To repair your Samson Meteor, use our service manual.
  1. Samson Meteor Teardown, Remove Perimeter Screws: step 1, image 1 of 2 Samson Meteor Teardown, Remove Perimeter Screws: step 1, image 2 of 2
    • There are 2 screws on the outside of the mic that we need to remove to get inside
    • They marked with a white circle.
    • A Phillips headscrew driver is required.
    Ask FixBot
  2. Samson Meteor Teardown, Removing capsule housing: step 2, image 1 of 2 Samson Meteor Teardown, Removing capsule housing: step 2, image 2 of 2
    • After removing the screws, the capsule housing should be able to be removed. Remove it slowly there are still wires attached coming from the microphone capsule and a ground wire.
    • To separate the housing, Remove the 4 screws highlighted in blue to allow you to remove a cover and then allow you to separate the housing and the capsule in its shock mount as shown in image 2
    Ask FixBot
  3. Samson Meteor Teardown, Removing main PCBs: step 3, image 1 of 1
    • To remove the main pcb, we firstly need to remove the pegs holding the LED indicator board to get better access to the screws holding the bottom pcb down as shown in image 1
    Ask FixBot
  4. Samson Meteor Teardown, Freedom!: step 4, image 1 of 1
    • With the screws out, you should be able to pull the main board out and there you have it! Teardown complete.
    Ask FixBot
Neville Davids
846 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 44
All Time: 798
