SYNOLOGY DS718+ Teardown
    1. SYNOLOGY DS718+ Teardown, Case presentation:  front panel: step 1, image 1 of 1
      • This NAS DS718 + is equipped with 4 GB of RAM (6 GB max.), an INTEL Celeron J3455 64-bit Quad processor, two bays for SATA drives (HDD, or SSD).
      • FRONT PANEL : you can notice on the right side, disks LEDs disapeared. You can find them now just on the top of the disk bays.
      • status LEDs
      • power buton (startup / shutdown)
      • 1 x USB 3 port
      • "copy" buton
      • 2 x disk support (caddy / cage)
      • disk bay lock
      Ask FixBot
    2. SYNOLOGY DS718+ Teardown, Cas presentation: rear panel: step 2, image 1 of 1
      • REAR PANEL
      • 1 x 92mm fan
      • 2 x EHTERNET RJ45 Gigabit port
      • 2 x USB 3 port
      • 1 x eSATA port
      • 1 x power connector
      • 1 x Kensington security incision (K-lock)
      • RESET buton
      Ask FixBot
    3. SYNOLOGY DS718+ Teardown, Backplane and memory access: step 3, image 1 of 3 SYNOLOGY DS718+ Teardown, Backplane and memory access: step 3, image 2 of 3 SYNOLOGY DS718+ Teardown, Backplane and memory access: step 3, image 3 of 3
      • Before teardown, unlock the disk media with the key.
      • It's a new appreciable feature, the memory slots are now directly reachable.
      • first memory slot
      • seonc memory slot (not populated)
      • The previous revision (DS716+ II) allowed this operation but a piece of metal prevent to remove memory.
      Ask FixBot
    4. SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: step 4, image 1 of 3 SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: step 4, image 2 of 3 SYNOLOGY DS718+ Teardown, Teardown: Rear Panel - Step 1 / 3: step 4, image 3 of 3
      • 1 - Remove the two screws placed under the NAS, on rear side.
      • 2 - Remove the screw placed in the middle of the rear panel.
      Ask FixBot
    5. SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: step 5, image 1 of 3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: step 5, image 2 of 3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 2 / 3: step 5, image 3 of 3
      • To remove the rear panel …
      • slightly pull the lower part of the rear panel so that the lugs do not touch the case, then ...
      • drag the facade upwards …
      • The back cover is held by two notches into the case.
      Ask FixBot
    6. SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: step 6, image 1 of 3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: step 6, image 2 of 3 SYNOLOGY DS718+ Teardown, Teardown: rear panel - step 3 / 3: step 6, image 3 of 3
      • Once removed, remove the fan connector from the motherboard.
      Ask FixBot
    7. SYNOLOGY DS718+ Teardown, Removing the Metal Housing: step 7, image 1 of 3 SYNOLOGY DS718+ Teardown, Removing the Metal Housing: step 7, image 2 of 3 SYNOLOGY DS718+ Teardown, Removing the Metal Housing: step 7, image 3 of 3
      • Once the rear panel is removed, the housing can be removed. To do so drag the cover about 1 cm to the back of the NAS then lift the hood upwards.
      Ask FixBot
    8. SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: step 8, image 1 of 3 SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: step 8, image 2 of 3 SYNOLOGY DS718+ Teardown, Naked case before disassembling metal housing: step 8, image 3 of 3
      • Now remains the front to remove ...
      • Here are some photographs of the case and the internal structure + screws.
      Ask FixBot
    9. SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: step 9, image 1 of 3 SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: step 9, image 2 of 3 SYNOLOGY DS718+ Teardown, Teradown: front panel - step 1 / 2: step 9, image 3 of 3
      • Remove the two screws under the box on the front side and then ...
      • in the same way as for the rear panel, lift the hood slightly ...
      Ask FixBot
    10. SYNOLOGY DS718+ Teardown, Teardown: front panel - step 2 / 2: step 10, image 1 of 2 SYNOLOGY DS718+ Teardown, Teardown: front panel - step 2 / 2: step 10, image 2 of 2
      • and remove the front panel …
      Ask FixBot
    11. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: step 11, image 1 of 3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: step 11, image 2 of 3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 1/3: step 11, image 3 of 3
      • x 4 screws to remove …
      • x 2 on the right side panel
      • and x 2 on the upper part
      Ask FixBot
    12. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: step 12, image 1 of 3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: step 12, image 2 of 3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 2/3: step 12, image 3 of 3
      • This part is delicate to assembly as to disassembly. Read full instructions carefully before handling.
      • The guidance remains relatively accurate but the connector for the LED card drives is fragile. Do not force when removing or inserting the side flange.
      • electronic card LED disks
      • riser for SATA backplane (electronic card or daughter card)
      • electronic card riser (USB and e-SATA)
      Ask FixBot
    13. SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: step 13, image 1 of 3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: step 13, image 2 of 3 SYNOLOGY DS718+ Teardown, Teardown: crankcase and expansion card 3/3: step 13, image 3 of 3
      • INSTRUCTIONS :
      • use both hands ...
      • pull gradually ...
      • everything must come without forcing!
      • Pay attention also to the metallic tape ... take it off if possible!
      Ask FixBot
    14. SYNOLOGY DS718+ Teardown, Teardown: motherboard and memory: step 14, image 1 of 2 SYNOLOGY DS718+ Teardown, Teardown: motherboard and memory: step 14, image 2 of 2
      • motherboard (processor side)
      • memory card
      • last pictures are bad …
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
6 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Sébastien
4,739 Reputation
6 Guides authored
AEM (ANIMA EX MACHINA) Member of AEM (ANIMA EX MACHINA)
Business
1 Member
72 Guides authored
4 Guide Comments
1 hour? I did it in 20 minutes that's teardown and reassembly!!?!
Ken Richner - Reply Share
PLZ read the introduction more carefully !
Sébastien - Reply Share
How to replace a larger heat pipe radiator??
love3kkk - Reply Share
Any suggestions on Mother board update for the DS218+ & DS718+ ?
WA FOR SALE - Reply Share
Past 24 Hours: 6
Past 7 Days: 52
Past 30 Days: 182
All Time: 11,202
