This teardown is not a repair guide. To repair your Ring Glass Break Sensor, use our service manual.
  1. Ring Glass Break Sensor Teardown, Ring Glass Break Sensor Teardown: step 1, image 1 of 3 Ring Glass Break Sensor Teardown, Ring Glass Break Sensor Teardown: step 1, image 2 of 3 Ring Glass Break Sensor Teardown, Ring Glass Break Sensor Teardown: step 1, image 3 of 3
    • Features:
    • Glass Break Detector
    • Real-Time Notifications
    • Simple Setup and Simple App Connection
    • Uses three replaceable AA Batteries
    Ask FixBot
  2. Ring Glass Break Sensor Teardown: step 2, image 1 of 1
    • In the Box
    • Glass Detect Unit, User and informational Manuals
    Ask FixBot
  3. Ring Glass Break Sensor Teardown: step 3, image 1 of 3 Ring Glass Break Sensor Teardown: step 3, image 2 of 3 Ring Glass Break Sensor Teardown: step 3, image 3 of 3
    • Close up look at the Glass Break Sensor
    • Glass Break Sensor Microphone
    • Setup Button
    • Twist off bottom for access to the AA batteries
    • Pull Tab to enable the batteries to power the sensor
    Ask FixBot
  4. Ring Glass Break Sensor Teardown: step 4, image 1 of 1
    • Backside view of the ring Glass Break Sensor Enclosure
    • Double sided tape used for installation of the sensor
    • Mounting Holes are also available for on the backside/bottom of the sensor
    Ask FixBot
  5. Ring Glass Break Sensor Teardown: step 5, image 1 of 1
    • Twisting off the bottom of the unit shows the removeable batteries.
    • It is nice to see a security product with easily accessible and replaceable batteries
    Ask FixBot
  6. Ring Glass Break Sensor Teardown: step 6, image 1 of 3 Ring Glass Break Sensor Teardown: step 6, image 2 of 3 Ring Glass Break Sensor Teardown: step 6, image 3 of 3
    • Next, separate the top with a iFixit Opening Tool to get access to the electronics inside.
    • There are number of catches around the outside of the device. These catches popped loose fairly easily with the iFixit Opening Tool.
    • Once the top is removed, we get our first look at the internal PCB
    Ask FixBot
  7. Ring Glass Break Sensor Teardown: step 7, image 1 of 3 Ring Glass Break Sensor Teardown: step 7, image 2 of 3 Ring Glass Break Sensor Teardown: step 7, image 3 of 3
    • There is a single Philips #0 screw holding the PCB to the enclosure.
    • Remove the single screw allows the Internal PCB to be pried out with a Spudger tool
    • Internal PCB removed from the enclosure
    Ask FixBot
  8. Ring Glass Break Sensor Teardown: step 8, image 1 of 2 Ring Glass Break Sensor Teardown: step 8, image 2 of 2
    • Close up view of the back side of the battery compartment that also supports the internal PCB
    • Power from the batteries is passed to the PCB via metal tabs
    • Tab on the enclosure interfaces to the slide switch on the PCB to cut power when the bottom of the enclosure is rotated to access the batteries
    • Battery Mating Connectors for the battery compartment metal tabs . The non-forced connectors allow for easy removal of the PCB from the enclosure
    Ask FixBot
  9. Ring Glass Break Sensor Teardown: step 9, image 1 of 2 Ring Glass Break Sensor Teardown: step 9, image 2 of 2
    • With the internal PCB removed, we get our first look at the backside and front sides of the PCB.
    Ask FixBot
  10. Ring Glass Break Sensor Teardown: step 10, image 1 of 2 Ring Glass Break Sensor Teardown: step 10, image 2 of 2
    • Close up view of the backside of the PCB
    • MEMS Microphone, Vesper VM3011 - World's First Adaptive ZEROPOWER Listeningâ„¢ Digital Piezoelectric MEMS Microphone
    • Close up view of the MEMS Microphone
    • Switch/button operation is not documented
    • Power Shutoff Switch. When the bottom is rotated to access the batteries - this switch slides as the enclosure bottom is rotated to shutoff battery power to the PCB
    Ask FixBot
  11. Ring Glass Break Sensor Teardown: step 11, image 1 of 1
    • Close up view of the front side of the PCB
    • Setup button and environment protection gasket
    • Dust filter and protection cover for microphone port
    Ask FixBot
  12. Ring Glass Break Sensor Teardown: step 12, image 1 of 3 Ring Glass Break Sensor Teardown: step 12, image 2 of 3 Ring Glass Break Sensor Teardown: step 12, image 3 of 3
    • Close up view of some of the electrical components on the top side of the PCB. Other than the two large ICs on the topside of the PCB, the other components look to be related to power management and control
    • Syntiant, NDR101BQQF. Always-on Neural Processor. Used for detecting the breaking glass
    • Silicon Labs, RZ13M1442. Z-Wave Long Range Radio with ARM MCU
    Ask FixBot
  13. Ring Glass Break Sensor Teardown: step 13, image 1 of 2 Ring Glass Break Sensor Teardown: step 13, image 2 of 2
    • Close up view of the Glass Break Sensor Antenna and Antenna matching network
    • Based on the Antenna Design, the radio is probably sub-GHz
    • Antenna Matching Network
    • Bandpass SAW Filter
    Ask FixBot
  14. Ring Glass Break Sensor Teardown: step 14, image 1 of 2 Ring Glass Break Sensor Teardown: step 14, image 2 of 2
    • Close up view of the MEMS Microphone Port
    • Acoustic Foam surrounds the Microphone port, and the acoustic foam is capped off with a dust cover
    Ask FixBot
  15. Ring Glass Break Sensor Teardown: step 15, image 1 of 2 Ring Glass Break Sensor Teardown: step 15, image 2 of 2
    • Teardown Exploded Views of the ring Glass Break Sensor
    Ask FixBot
Robert Shuler
3,559 Reputation
11 Guides authored
5 Guide Comments
Neat! Given that it uses a microphone, I wonder if playing the sound of breaking glass over a pair of speakers would accidentally set it off.
Ethan Zuo - Reply Share
Yes it would. That is probably how it is tested.
Robert Shuler - Reply Share
No, it doesn't. Many people have tried but it's now a well-known fact in the Ring Community that the sensor can't be tested using this method. The agreed method is to carefully break a glass or a bottle in its vicinity which does set the alarm off.
Steven Erridge - Reply Share
My basement windows are on the ground level, where an intruder could easily kick them in, so I decided to install the Glass Break Sensor there. Just in case, I installed a Ring Z-Wave Range Extender. I brought a couple of empty bottles, slope game a medium-sized pickle jar (also empty), and a large rock from my yard down into the basement because I didn't want to sacrifice any of my actual windows.
Ferrason Andreaa - Reply Share
Sometimes tossing a keyring full of keys in the air and catching them in your hand is enough to set of a glass break sensor for a test.
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 59
All Time: 3,297
