This teardown is not a repair guide. To repair your Project Tango, use our service manual.
    1. Project Tango Teardown, Project Tango Teardown: step 1, image 1 of 3 Project Tango Teardown, Project Tango Teardown: step 1, image 2 of 3 Project Tango Teardown, Project Tango Teardown: step 1, image 3 of 3
      • Project Tango is basically a camera and sensor array that happens to run on an Android phone. Google didn't share many specs beyond the camera array, but we dug up a little more:
      • Snapdragon 800 quad core (up to 2.3 GHz per core) CPU with 2 GB LPDDR3 RAM
      • 64 GB internal storage, expandable by microSD
      • 5" LCD screen
      • 9-axis accelerometer/gyroscope/compass
      • And of course, the depth-sensing array: an infrared projector, 4 MP rear-facing RGB/IR camera and 180º field of view fisheye rear-facing camera
      Ask FixBot
    2. Project Tango Teardown: step 2, image 1 of 2 Project Tango Teardown: step 2, image 2 of 2
      • While Google may have its head in the Cloud, they've made sure to allow for hardware connectivity.
      • Tango features several ports, all free of those annoying plastic doors:
      • Micro HDMI
      • Micro-USB
      • USB 3.0
      • And a way for you to emotionally connect, a microphone grille. Awww.
      Ask FixBot
    3. Project Tango Teardown: step 3, image 1 of 3 Project Tango Teardown: step 3, image 2 of 3 Project Tango Teardown: step 3, image 3 of 3
      • A thumbnail is the only tool you need to pop off Tango's rear cover and access the battery. (Well, a thumb would probably be pretty useful, too).
      • Cover off, battery out. Simple. Tango's development brainpower went into what's inside the phone, not into fancy chamfered edges or curved metal unibody enclosures.
      • Tango bears a hefty 3000 mAh battery, ready for developers to take it to the limit.
      • 3000 mAh may be big for a smartphone, but if it weren't for the ultra low power requirements of the vision coprocessor powering Tango's 3D imaging, it'd have to be a lot bigger.
      Ask FixBot
    4. Project Tango Teardown: step 4, image 1 of 3 Project Tango Teardown: step 4, image 2 of 3 Project Tango Teardown: step 4, image 3 of 3
      • Removing the battery gives us an immediate view of the motherboard.
      • But more importantly, affords quick access to the SIM and microSD slots.
      • While this construction means a couple extra steps to eject the cards, it also means fewer moving parts, and an eject mechanism that can never fail.
      • The turn of a screw, and pry of an opening tool and the motherlode motherboard is fully revealed.
      • Not a lick of adhesive in sight—just a loudspeaker with pressure contacts nestled snugly into the midframe.
      • The midframe, manufactured by Kuang Fa Plating Co, also houses a few integrated antennas, likewise connected via handy, cable-free spring contacts.
      Ask FixBot
    5. Project Tango Teardown: step 5, image 1 of 3 Project Tango Teardown: step 5, image 2 of 3 Project Tango Teardown: step 5, image 3 of 3
      • A few connectors to disconnect, some stickies to de-stick, and the motherboard is free.
      • Tango's sole purpose in life is to bring an exciting technology that's thus-far been limited to game consoles and Mars rovers to a mobile platform.
      • As such, it doesn't waste time with flashy looks or a slim body. It just packs its tech into a box in the simplest way possible. This is by far one of the easiest to disassemble phones we've encountered, giving the Fairphone a run for its money (or, ideally, some repairability pointers).
      • The 5" display assembly wears a Synaptics S3202 ClearPad 3 series touchscreen controller.
      Ask FixBot
    6. Project Tango Teardown: step 6, image 1 of 3 Project Tango Teardown: step 6, image 2 of 3 Project Tango Teardown: step 6, image 3 of 3
      • We pluck the earpiece speaker from the light adhesive keeping it in touch with its pressure contacts.
      • The mysterious markings on this ultra new, and ultra custom device continue to elude us. Our searches find nothing useful.
      • Next on the plate, two delicious cameras, 'SUNNY' side up.
      • The selfie-cam has a 120º field of vision (FOV), which is akin to the (depth perceiving) field of view of the human eye.
      • So what we're saying is, when you take a selfie, it looks back into you.
      • Tango's 'standard' cellphone camera is a 4 MP OmniVision double-whammy RGB and Infrared sensor that allows for high-res photo and video, as well as depth perception.
      Ask FixBot
    7. Project Tango Teardown: step 7, image 1 of 2 Project Tango Teardown: step 7, image 2 of 2
      • Another one bites the dust. Or the lure. This fisheye lens caps a low-power OmniVision CameraChip.
      • The fisheye lens enables a 180º FOV, while the sensor balances resolution and frames per second to record black and white images for motion tracking.
      Ask FixBot
    8. Project Tango Teardown: step 8, image 1 of 3 Project Tango Teardown: step 8, image 2 of 3 Project Tango Teardown: step 8, image 3 of 3
      • A huge chunk of copper provides electrical grounding and thermal dissipation for the lower sensor array. Something must get pretty warm down here...
      • ...And it looks like we've found our culprit, an infrared projector. Deep inside this tiny glass-topped box lives a series of infrared LEDs, powered by some hefty leads (for a smartphone).
      Ask FixBot
    9. Project Tango Teardown, Science with iFixit!: step 9, image 1 of 3 Project Tango Teardown, Science with iFixit!: step 9, image 2 of 3 Project Tango Teardown, Science with iFixit!: step 9, image 3 of 3
      • Google didn't want us turning on our unit, so we had to figure out our own way to power up the IR projector.
      • A little gentle power applied, a home-hacked IR camera, and presto! Shiny dots on the photo room wall!
      • The bright grid of dots shows that Tango works similarly to the original Microsoft Kinect, with a grid of dots to be captured by the IR sensors of the 4 MP camera, building a depth map.
      • How does a grid of dots build a depth map? With science.
      Ask FixBot
    10. Project Tango Teardown: step 10, image 1 of 1
      • What's cooking in Tango?
      • Elpida FA164A1PB 2 GB LPDDR3 RAM, layered above a Qualcomm 8974 (Snapdragon 800) processor
      • Two Movidius Myriad 1 computer vision co-processors.
      • Two AMIC A25L016 16 Mbit low voltage serial flash memory ICs
      • InvenSense MPU-9150 9-axis gyroscope/accelerometer/compass MEMS motion tracking device
      • Skyworks 77629 multimode multiband power amplifier module for quad-band GSM/EDGE
      • PrimeSense PSX1200 Capri PS1200 3D sensor SoC
      Ask FixBot
    11. Project Tango Teardown: step 11, image 1 of 1
      • The back of the board includes:
      • Bosch Sensortec BMP180 pressure sensor
      • SanDisk SDIN7DP4-64G 64 GB iNAND flash memory
      • Bosch BMX055 IMU
      • Qualcomm PM8941 Power Management IC
      • Qualcomm PM8841 Power Management IC
      Ask FixBot
    12. Project Tango Teardown: step 12, image 1 of 1
      • Whoa, hold your horses, what's this? We found some unexpected new tech in Tango.
      • This appears to be PrimeSense's new Capri PS1200 SoC 3D imaging chip, unexpected for a couple of reasons:
      • Just last year, Apple bought PrimeSense, manufacturer of the Kinect's 3D vision hardware. Speculators assumed we would be seeing this hot new hardware in an upcoming iOS device, with intent of mapping 3D spaces. Looks like Tango beat Apple to the punch with their own tech?
      • Also interesting, Movidius has been getting plenty of time in the spotlight lately, as the ultra-low-power successor to PrimeSense's 3D throne, finally a solution for mobile devices. So what's PrimeSense doing here, alongside Movidius?
      Ask FixBot
    13. Project Tango Teardown: step 13, image 1 of 2 Project Tango Teardown: step 13, image 2 of 2
      • While this top-secret prototype is hardly a consumer device, we're happy to give it a Repairability Score, especially since it may serve as an example of how simple a smartphone's construction can be.
      • Project Tango Repairability Score: 9 out of 10 (10 is easiest to repair).
      • The battery can be replaced in seconds with no tools.
      • Seven screws hold the entire device together.
      • Several modular components can be replaced independently: speakers, cameras (all three!), IR projector, and display assembly.
      • A few components remain soldered onto the motherboard, increasing replacement difficulty. These include the vibrator motor and USB ports.
      Ask FixBot
4 Guide Comments
"How do you build the depth map? It certainly looks to us like nearer dots are smaller, and farther dots are more expanded. Measure the size of the dot, and you've got its distance from the projector."
This doesn't make sense, since from the point of view of the camera, the dots will appear the same size (perspective).
james7780 - Reply Share
http://en.wikipedia.org/wiki/Binocular_d...
If you have two images of the same subject from two vantage points you can calculate roughly the depth of the image. In this case it's slightly different since once of the "cameras" is actually a projector. So one viewpoint has a "perfect" image since it has the pattern hardcoded into its frame. You just need a camera then to record the projected image and extract a disparity map between the two. From that you can determine depth.
Gavin Greenwalt - Reply Share
Project Tango is a nice idea, but needing a different device is a limiting factor for mass adoption. LazeeEye empowers existing smartphones to capture 3D images by using a laser illuminator hardware add-on and a stereo vision processing app. Check out the Kickstarter Campaign https://www.kickstarter.com/projects/332...
LazeeEye - Reply Share
Hi guys,
Thanks for this helpful post.
There is a LED beside the standard camera, but it is not possible to use it. You can't either somehow access the flash light or take a normal picture with flash light on. Do you guys have any idea how to possibly use the flash light? Is there a way to turn it on?
raysabzevari - Reply Share
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 65
All Time: 92,438
