Introduction
Go to step 1 ↓The Philips Hue Pro is remarkably easy to disassemble. Unlike many modern devices, nothing is glued in place, and it is held together by just two screws. These screws are not treated with thread-locking compound, which means you can open the unit without worrying about breaking anything or voiding the warranty. This guide will walk you step by step through the process, showing how simple it is to access the internal components for inspection, repair, or modification.
Tools
1. Pry off the bottom rubber with your fingernail (no sharp tools).
2. Remove the two screws in the corners.
3. Lift off the bottom plate.
4. Gently flip the main board upward to access it. Safe and simple.
