This teardown is not a repair guide. To repair your DualSense, use our service manual.
  1. PS5 Controller Trigger Teardown, PS5 Controller Trigger Teardown: step 1, image 1 of 1
    • Once you have opened your controller to this point remove those 4 screws to separate the middle frame from the outer frame.
    Ask FixBot
  2. PS5 Controller Trigger Teardown: step 2, image 1 of 1
    • Once you have separated the middle frame from the outer remove the 2 screws securing the trigger assembly to the middle frame. Remove the opposite 2 if you are changing parts on the other side.
    Ask FixBot
  3. PS5 Controller Trigger Teardown: step 3, image 1 of 1
    • The trigger assembly comes out easy now.
    Ask FixBot
  4. PS5 Controller Trigger Teardown: step 4, image 1 of 2 PS5 Controller Trigger Teardown: step 4, image 2 of 2
    • Remove these 3 screws on this side of the trigger assembly and one more hidden behind the ribbon cable on the other side.
    Ask FixBot
  5. PS5 Controller Trigger Teardown: step 5, image 1 of 2 PS5 Controller Trigger Teardown: step 5, image 2 of 2
    • Your trigger assembly is now open. Gently remove the plastic piece to reveal more of the metal pin. Refer to second pic. Pull the metal pin holding the trigger out using a pliers and this will free up the assembly for the button film replacement.
    Ask FixBot
  6. PS5 Controller Trigger Teardown: step 6, image 1 of 1
    • The metal pin is now out and the trigger is free.
    Ask FixBot
  7. PS5 Controller Trigger Teardown: step 7, image 1 of 1
    • Remove the button conductive rubber and now replace the button film.
    Ask FixBot
  8. PS5 Controller Trigger Teardown: step 8, image 1 of 1
    • For reassembly reverse the order. Congratulations. You have successfully replaced your R1, R2 or L1, L2 button film.
    Ask FixBot
vickyjean1007
193 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 49
Past 7 Days: 355
Past 30 Days: 1,508
All Time: 30,170
