Video Overview
This teardown is not a repair guide. To repair your OnePlus 8 Pro, use our service manual.
    1. Final Thoughts
      • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
      • Many components are modular and can be individually replaced.
      • Display replacements, which are the most common repairs, are not prioritized in the design.
      • The primary access point for all repairs, the rear panel, is firmly glued in place.
      Repairability Score
      4
      Repairability 4 out of 10
      (10 is easiest to repair)
5 Guide Comments
No wallpaper? Please!
rafboricua - Reply Share
When I was disassembling OP8 Pro in order to replace my display, I did not pay attention there are screws with different sizes . If I use a wrong screw, it can damage new display. Can you help me ? Do you have correct screw sequence point each size?
Claudio Varizo - Reply Share
Long screws go to upper side (where motherboard and cameras places) and short screws are for bottom side. Two shortest screws hold the usb connector
geordead - Reply Share
I sure do miss the days when the teardowns/ came with pictures so that I can see the locations of screws and such in between steps. :\
Guess I'll go find something by someone else for help.
Kediil - Reply Share
Is the ub-c charging port replaceable and where can i get the part?
Timothy Tarr - Reply Share
Past 24 Hours: 2
Past 7 Days: 37
Past 30 Days: 170
All Time: 32,376
