Video Overview
This teardown is not a repair guide. To repair your OnePlus 7 Pro, use our service manual.
    1. Final Thoughts
      • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
      • Many components are modular and can be individually replaced.
      • Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
      • While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
      • The primary access point for all repairs, the rear panel, is firmly glued in place.
      Repairability Score
      4
      Repairability 4 out of 10
      (10 is easiest to repair)
6 Guide Comments
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - Reply Share
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge - Reply Share
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - Reply Share
OnePlus 7 pro 8/256
Anita Jajoriya - Reply Share
do i need to remove the pop up camera if i want to change the screen?
romain.collet - Reply Share
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 210
All Time: 76,702
