Tools
This teardown is not a repair guide. To repair your Nvidia Shield Controller, use our service manual.
    1. Nvidia Shield Controller Teardown, Nvidia Shield Controller Teardown: step 1, image 1 of 2 Nvidia Shield Controller Teardown, Nvidia Shield Controller Teardown: step 1, image 2 of 2
      • Nvidia Shield Normal Controller, without Display, so it's just a controller if you don't have other shield device
      • Micro-USB 2.0
      • 3.5 mm stereo headphone jack
      • Charge indicator
      • Still don't know how this controller connected to PC without cables, the controller can be connected to a Nvidia Shield through WiFi but no idea if this works with pc.
      Ask FixBot
    2. Nvidia Shield Controller Teardown: step 2, image 1 of 3 Nvidia Shield Controller Teardown: step 2, image 2 of 3 Nvidia Shield Controller Teardown: step 2, image 3 of 3
      • Flipping over the device reveals 6 screws. No hidden screws here.
      • 6*screws, use T7 screwdriver for all of screws。
      • Careful, you will need some force to open the clips holding the device together.
      • Once you are inside the device remove the two ribbon cables.
      Ask FixBot
    3. Nvidia Shield Controller Teardown, Vibration Motors: step 3, image 1 of 2 Nvidia Shield Controller Teardown, Vibration Motors: step 3, image 2 of 2
      • Remove two cable for the vibration motors and one cable for the battery.
      • There are 2 Vibration motors
      Ask FixBot
      • Remove the two screws holding the logic board to the device.
      • Carefully remove the logic board.
      Ask FixBot
    4. Nvidia Shield Controller Teardown, Battery: step 5, image 1 of 2 Nvidia Shield Controller Teardown, Battery: step 5, image 2 of 2
      • we can found battery part under the motherboard
      • Screw*4
      • LC18650 Lithium-ion Battery: 3.6V/2200mAh/7.92Wh
      Ask FixBot
    5. Nvidia Shield Controller Teardown, Motherboard: step 6, image 1 of 2 Nvidia Shield Controller Teardown, Motherboard: step 6, image 2 of 2
      • Main PCB - Front:
      • TLV320AIC3204 (Very Low-Power Stereo Audio CODEC)
      • Atmel ATXMEGA32A4U-AU (8-bit Microcontroller)
      • Potentiometers
      • Main PCB - Back:
      • Microchip SST25WF020A (SPI Flash 2Mbit 1.8V)
      • Ozmo2000 431-B0 (WiFi Integrated Chip)
      • ADG3 3088CP (Unknown)
      Ask FixBot
    6. Nvidia Shield Controller Teardown, LT&RT: step 7, image 1 of 3 Nvidia Shield Controller Teardown, LT&RT: step 7, image 2 of 3 Nvidia Shield Controller Teardown, LT&RT: step 7, image 3 of 3
      • Remove 6*screw
      • careful,don't broke the potentiometer
      Ask FixBot
    7. Nvidia Shield Controller Teardown: step 8, image 1 of 3 Nvidia Shield Controller Teardown: step 8, image 2 of 3 Nvidia Shield Controller Teardown: step 8, image 3 of 3
      • cover part
      • 4*screw
      • PIC32MX120F032D-I/PT (32-bit Microcontroller)
      • PIC18F26K22-I/ML (8-bit Microcontroller)
      Ask FixBot
90 Reputation
1 Guide authored
19 Guide Comments
Where is the Shield console teardown?
Steve Hanson - Reply Share
I brought the controller to the hardware store and found that a T6 fit perfect. I bought it and used it, worked fine. I know the description says T7. May be a mistake
Farrid Mailloux - Reply Share
Farrid is Correct I have both a T7 and T6 Screwdriver and the T7 IS TOO BIG!, T6 fits perfectly. Just a heads up to anyone who needs to go out and but a Single screwdriver.
drestine - Reply Share
You are right. It’s T6, not T7.
nguyen bui thanh - Reply Share
Looking to replace ribbon cables. Anyone know where i can buy them?
Dave Miller - Reply Share
Past 24 Hours: 3
Past 7 Days: 31
Past 30 Days: 117
All Time: 13,378
