Introduction
Go to step 1 ↓
This is the chip ID of the Nintendo Switch 2's main board.
Check out our Nintendo Switch 2 teardown for more details.
Special thanks to our community member Chunglin Chin for contributing to this!
This teardown is not a repair guide. To repair your Nintendo Switch 2, use our service manual.
    1. Nintendo Switch 2 Chip ID, Front side: step 1, image 1 of 2 Nintendo Switch 2 Chip ID, Front side: step 1, image 2 of 2
      • NVIDIA GMLX30-A1 applications processor w/ GPU
      • Micron MT62F768M64D4EK-026 WT:B 6 GB LPDDR5 SDRAM memory
      • Infineon CP10359AT USB type-C controller
      • Likely Nintendo B2423 Game Card reader controller
      • Genesys Logic GL852G quad-port USB 2.0 hub
      • Analog Devices MAX17050 battery fuel gauge
      • Diodes Incorporated PI2SSD3212NCE 14-bit 2:1 SSD switch
      Ask FixBot
    2. Nintendo Switch 2 Chip ID: step 2, image 1 of 1
      • Texas Instruments TPS2121 dual-input, single-output power multiplexer
      • Likely Analog Devices MAX18000 boost converter
      • Texas Instruments TPS62825 2 A step-down converter
      • Texas Instruments TPS25200 5 V eFuse
      • Texas Instruments TPS2553 USB power switch
      • Texas Instruments TS5A23166 dual SPST analog switch
      Ask FixBot
    3. Nintendo Switch 2 Chip ID: step 3, image 1 of 1
      • STMicroelectronics accelerometer & gyroscope
      • Texas Instruments TMP451 temperature sensor
      Ask FixBot
    4. Nintendo Switch 2 Chip ID, Back side: step 4, image 1 of 2 Nintendo Switch 2 Chip ID, Back side: step 4, image 2 of 2
      • SK hynix HN8T15DEHKX075 256 GB NAND flash w/ UFS 3.1 memory controller
      • Analog Devices MAX77851SAWJ power management
      • Renesas DA9092 power management
      • Analog Devices MAX77986 single cell Li+ battery charger
      • Intelligo Technology IG2200 audio/voice processor
      • Realtek ALC5658 audio codec
      • Analog Devices MAX77801 buck-boost converter
      Ask FixBot
    5. Nintendo Switch 2 Chip ID: step 5, image 1 of 1
      • Nisshinbo Micro Devices R1214Z dual-channel step-up white LED driver
      • Rohm BD8316GWL step-up & inverted DC-DC converter
      Ask FixBot
    6. Nintendo Switch 2 Chip ID, Back side - Connectivity: step 6, image 1 of 1
      • MediaTek MT3681AEN WiFi & Bluetooth controller
      Ask FixBot
    7. Nintendo Switch 2 Chip ID, Joy-Con front side: step 7, image 1 of 2 Nintendo Switch 2 Chip ID, Joy-Con front side: step 7, image 2 of 2
      • Texas Instruments BQ25618 1.5 A buck battery charger
      • Likely Analog Devices MAX3864xA buck converter
      Ask FixBot
    8. Nintendo Switch 2 Chip ID, Joy-Con front side - Connectivity: step 8, image 1 of 1
      • MediaTek MT3689BCA Bluetooth SoC
      Ask FixBot
    9. Nintendo Switch 2 Chip ID, Joy-Con back side: step 9, image 1 of 2 Nintendo Switch 2 Chip ID, Joy-Con back side: step 9, image 2 of 2
      • Analog Devices MAX98388 class-D audio amplifier
      Ask FixBot
    10. Nintendo Switch 2 Chip ID, Joy-Con back side - Connectivity: step 10, image 1 of 1
      Ask FixBot
    11. Nintendo Switch 2 Chip ID, Joy-Con back side - Sensors: step 11, image 1 of 1
      • TDK-InvenSense ICM-42607-PN 6-axis accelerometer & gyroscope
      • AKM Semiconductor AK09919C 3-axis electronic compass
      Ask FixBot
4 Guide Comments
IG2200 from Intelligo, interesting. I suspected they might have used something like RTX Voice when people commented how the microphone sounds pretty decent even when sitting 5-6 feet away from the Switch 2 but looks like they chose a dedicated solution.
Alex L - Reply Share
And the screen?
Marcus von Jahn - Reply Share
Interesting, looks like Nintendo has "returned" to Mediatek from Broadcom (the DS WiFi adapter used a Ralink controller), though that isn't accurate, as the DS had a Qualcomm controller.
Moriel Ever - Reply Share
Greetings:
Does anyone have a clear picture of the component: AKM Semiconductor AK09919C 3-axis electronic compass. In the Joycon 2 board. When clicking the picture the part number looks fuzzy.
Yankito - Reply Share
Past 24 Hours: 63
Past 7 Days: 358
Past 30 Days: 1,475
All Time: 30,974
