Video Overview
This teardown is not a repair guide. To repair your Nintendo GameCube Gameboy Player, use our service manual.
    • Place the Game Boy Player flat on a surface, with the top surface that would mate with the Gamecube facing up, Nintendo logo on the bottom.
    • Use a gamebit screwdriver to loosen and remove eight screws around the top of the surface.
    Ask FixBot
    • After the screws are removed the top piece can be lifted off of the rest of the unit.
    • Try grabbing around the raised portion where the socket would mate with the bottom of the Gamecube, and and lift straight up and out.
    Ask FixBot
    • Use a Phillips head screwdriver to remove 11 screws installed all around the metal heat sink.
    • The metal shielding around the socket port is a separate smaller piece and should be removed first by grabbing around it and pulling up and away.
    • Then, the rest of the outer shielding can be pulled up and away.
    Ask FixBot
    • With the metal shielding removed, the motherboard can be lifted up and away from the bottom shell of the Game Boy Player.
    Ask FixBot
    • The shell has another layer of shielding in the track of the motherboard, and this can be pulled up and away after removing the motherboard.
    • Additional removable pieces include:
    • two poles, one on the side and another near the corner,
    • a small flat piece near the front above the cartridge slot that would mask over the extension port,
    • and a long thin piece that goes across the shell, attached by a spring, which overall act as the cartridge's ejector.
    Ask FixBot
tayola
10,147 Reputation
44 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 55
All Time: 1,519
