This teardown is not a repair guide. To repair your Nintendo 64 Controller, use our service manual.
    1. Nintendo 64 Controller Teardown, Nintendo 64 Controller Teardown: step 1, image 1 of 3 Nintendo 64 Controller Teardown, Nintendo 64 Controller Teardown: step 1, image 2 of 3 Nintendo 64 Controller Teardown, Nintendo 64 Controller Teardown: step 1, image 3 of 3
      • Behold the glorious retro controller face, then forget about it because you will flip the controller for the rest of the teardown.
      • Use the size #1 Philips to remove the 7 screws on the back of the controller.
      • Use the size #0 Philips to remove the smaller screws in the controller pak slot.
      Ask FixBot
    2. Nintendo 64 Controller Teardown: step 2, image 1 of 1
      • Remove the back plate. You can now see the:
      • Power Input
      • Game Pak Slot
      • Trigger Button Assemblies
      • Z Button Assembly
      • Joystick Module
      Ask FixBot
    3. Nintendo 64 Controller Teardown: step 3, image 1 of 1
      • Using a spudger or similar tool, carefully pry the Z button assembly from the joystick module.
      • Remove the 3 size #0 screws holding in the joystick module.
      • Remove the joystick cable from the main board.
      Ask FixBot
    4. Nintendo 64 Controller Teardown: step 4, image 1 of 2 Nintendo 64 Controller Teardown: step 4, image 2 of 2
      • Remove the joystick module.
      • This particular module is a third party replacement. Yours may look different.
      Ask FixBot
    5. Nintendo 64 Controller Teardown: step 5, image 1 of 2 Nintendo 64 Controller Teardown: step 5, image 2 of 2
      • Remove the main board and trigger assemblies.
      • Your controller is now fully disassembled!
      Ask FixBot
    6. Nintendo 64 Controller Teardown: step 6, image 1 of 1
      • Full IC Identification:
      • You may need to enlarge it to view the text.
      Ask FixBot
Ian
1,486 Reputation
2 Guides authored
Kid fixers Member of Kid fixers
Community
225 Members
2,046 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 58
Past 30 Days: 263
All Time: 20,939
