Introduction
Go to step 1 ↓
This exploded view shows the housing and the main electronic components of the Nintendo 3DS NFC reader.
This teardown is not a repair guide. To repair your Nintendo 3DS NFC reader, use our service manual.
    1. Nintendo 3DS NFC reader exploded view, Outside of the case: step 1, image 1 of 3 Nintendo 3DS NFC reader exploded view, Outside of the case: step 1, image 2 of 3 Nintendo 3DS NFC reader exploded view, Outside of the case: step 1, image 3 of 3
      • This player is shaped like a cylindrical pebble approximately 7.5 cm in diameter and 3 cm thick. It has a hatch that allows access to the batteries.
      Ask FixBot
    2. Nintendo 3DS NFC reader exploded view, Case disassembly: step 2, image 1 of 3 Nintendo 3DS NFC reader exploded view, Case disassembly: step 2, image 2 of 3 Nintendo 3DS NFC reader exploded view, Case disassembly: step 2, image 3 of 3
      • The case is held closed with 4 tri-point Y1 screws; once removed, you can access the PCB.
      Ask FixBot
    3. Nintendo 3DS NFC reader exploded view, Separating the PCB: step 3, image 1 of 2 Nintendo 3DS NFC reader exploded view, Separating the PCB: step 3, image 2 of 2
      • To separate the PCB from the case, simply unclip it from its two notches.
      • Note that the PCB only has components on one side.
      • The NFC coil is 57 mm in diameter.
      Ask FixBot
    4. Nintendo 3DS NFC reader exploded view, PCB analysis: step 4, image 1 of 3 Nintendo 3DS NFC reader exploded view, PCB analysis: step 4, image 2 of 3 Nintendo 3DS NFC reader exploded view, PCB analysis: step 4, image 3 of 3
      • The PCB consists of a microcontroller unit of unknown reference and a Broadcom BCM20792 KMLG NFC controller.
      • The IR transceiver is made of 2 parts, likely one dedicated to receiving and the other to transmitting.
      • Two LEDs are present to indicate the communication status to the user.
      Ask FixBot
lukas baudet
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 36
All Time: 371
