This teardown is not a repair guide. To repair your Moodo Smart Aroma Diffuser, use our service manual.
  1. Moodo Smart Aroma Diffuser  Teardown, Device: step 1, image 1 of 2 Moodo Smart Aroma Diffuser  Teardown, Device: step 1, image 2 of 2
    • The device can be opened by removing the 4 Philips screws visible from the bottom
    Ask FixBot
  2. Moodo Smart Aroma Diffuser  Teardown, Fan assembly: step 2, image 1 of 1
    • The fan and air guidance assembly is attached to the main PCB with 2 screws.
    • Each fan has one connector for power and one for the pod sensor - these need to be disconnected from the PCB before removing the fan assembly. If you want to replace a fan, you will need to unhook the sensor cables from the sides.
    • Fans used are: 1604KL-01W-B39-B00 NMB Technologies DC Fans DC Axial Fan, 40x10mm, 5VDC, 4.2CFM
    Ask FixBot
  3. Moodo Smart Aroma Diffuser  Teardown, PCB: step 3, image 1 of 2 Moodo Smart Aroma Diffuser  Teardown, PCB: step 3, image 2 of 2
    • The main PCB connects to the control PCB with a ribbon cable.
    • It can be removed with 2 screws.
    • The 2 cell battery pack is located under the main PCB.
    Ask FixBot
Markus
132 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,206
