Introduction
Go to step 1 ↓
Mini Muscle Massage Gun,Deep Tissue Percussion Massage Gun with 6 Speeds and 4 Heads, Type-C Charging,Ultra Quiet, Portable Electric Handheld Body Massager for Neck Back Pain Relief Tear down. 6 Variable Speed & 4 Massage Heads - The mini massage gun has 6-speed strength levels ranging from 1200 to 3200 rpm, which awakes your whole body muscles, from daily massage to deep massage. 4 interchangeable replacement heads fit your diverse needs and bring you a precision massage experience.
  • Powerful & Super Quiet - Our massage gun deep tissue has a 30W high-torque motor and quite glide noise reduction technology that brings high power but low noise (35dB - 45dB) experience. You can use it at home, gym and office without causing a disturbance.
  • Portable & 15 Minutes Auto-Off Protection - This percussion massage gun weighs only 580g, the hand feels light, comfortable to hold. It is designed with a 15 minute auto-off setting to prevent overheating to extend the life of the motor.
  • High Battery Capacity & Type-c Charging - The muscle massage gun is equipped with a 1800mAh high-quality rechargeable lithium battery, that ensures 2-6 hours working time, and only takes 3-4 hours to fully charged. Equipped with a Type-C port that allows it to be charged as quickly and easily as a smartphone.
  • Relax & Recover - The hand held massager features to relieve you from muscle tightness, soreness and back stiffness, a best way to rejuvenate muscle tissue and recover from body painfulness. The mini massager will help you in relieving fatigue after sports, workout, hiking, and climbing, which also suits for sedentary and postoperative recovery.
Tools
This teardown is not a repair guide. To repair your Mini muscle massage gun, use our service manual.
    1. Mini Muscle Massage Gun, Mini Muscle Massage Gun: step 1, image 1 of 3 Mini Muscle Massage Gun, Mini Muscle Massage Gun: step 1, image 2 of 3 Mini Muscle Massage Gun, Mini Muscle Massage Gun: step 1, image 3 of 3
      • Device Overview
      • Dimension.
      • Red :98.30mm
      • Orange:116mm
      • Yellow:132.82mm
      • Diameter dimension
      • Red: 48.62mm Diameter
      • Hello 98.8mm Diameter
      Ask FixBot
    2. Mini Muscle Massage Gun, Screws: step 2, image 1 of 3 Mini Muscle Massage Gun, Screws: step 2, image 2 of 3 Mini Muscle Massage Gun, Screws: step 2, image 3 of 3
      • To remove and disassemble the shell. Follow these instructions.
      • Unscrew all the screw hi lighted in the images.
      • unscrew the cap located at the tip of the device.
      Ask FixBot
    3. Mini Muscle Massage Gun: step 3, image 1 of 3 Mini Muscle Massage Gun: step 3, image 2 of 3 Mini Muscle Massage Gun: step 3, image 3 of 3
      • Twist and remove the cap located on the back. hi lighted in red.
      • Carefully removed the connector from the PCB
      • Twist and removed the bottom cap. Hi lighted in yellow
      Ask FixBot
    4. Mini Muscle Massage Gun, Dimension internal components.: step 4, image 1 of 2 Mini Muscle Massage Gun, Dimension internal components.: step 4, image 2 of 2
      • Battery length.
      • Orange. 66.64mm
      • Yellow: 71.28mm.
      • Battery Diameter.
      • Blue 42mm
      • Massage conector
      • Red:103.13mm
      Ask FixBot
    5. Mini Muscle Massage Gun: step 5, image 1 of 3 Mini Muscle Massage Gun: step 5, image 2 of 3 Mini Muscle Massage Gun: step 5, image 3 of 3
      • Remove the top shell from the body.
      • Using a screw driver removed part hi lighted in red from the motor
      • Remove screw hi lighted in yellow. Removing this screw will disconnect the motor to the body.
      Ask FixBot
    6. Mini Muscle Massage Gun, Teardown components weight Shell: step 6, image 1 of 3 Mini Muscle Massage Gun, Teardown components weight Shell: step 6, image 2 of 3 Mini Muscle Massage Gun, Teardown components weight Shell: step 6, image 3 of 3
      • Device handle shell is weighted at 50g . Made from ABS plastic. Injection mold
      • Top shell is weighted at 19g. Made from ABS plastic
      • The tip which is used to hold the shell parts together is weighted at 19g. Made from ABS plastic
      Ask FixBot
    7. Mini Muscle Massage Gun, Teardown components cap: step 7, image 1 of 3 Mini Muscle Massage Gun, Teardown components cap: step 7, image 2 of 3 Mini Muscle Massage Gun, Teardown components cap: step 7, image 3 of 3
      • Back cap. This include the PCB. is weighted at 14g. Made from ABS plastic.
      • Bottom cap is weighted at 7g. Made from ABS plastic
      • Decoration parts. Non functional weighted at 3g.
      Ask FixBot
    8. Mini Muscle Massage Gun, Internal components.: step 8, image 1 of 3 Mini Muscle Massage Gun, Internal components.: step 8, image 2 of 3 Mini Muscle Massage Gun, Internal components.: step 8, image 3 of 3
      • Battery. Weighted at 72g. use to power the devic. 1800mAh lithium battery
      • Part connected to the device motor. Use as a connect to various massager head. Weighted at 19g.
      • Device motor. Weighted at 246g.
      Ask FixBot
    9. Mini Muscle Massage Gun, Massage gun interchanagble head: step 9, image 1 of 1
      • Red: Nylon: injection moulded
      • Blue: Rubber: injection moulded
      • Yellow: Eva foam:
      Ask FixBot
    10. Mini Muscle Massage Gun, Teardown complete overview: step 10, image 1 of 1
      • Device design is quite simple which encourage repairability.
      • most part found in the device and be easily replace by purchasing them online
      • 1800mAh high-quality rechargeable lithium battery can be easily replaced online.
      • 30W high-torque motor can also be replace. Purchased online. https://www.hisgifts.com.au/products/sta...
      • Any broken parts of the shell can easily be fixed with 3d printing.
      • most screw can also be found online
      Ask FixBot
Nathasorn Pantratthanamongkol
145 Reputation
1 Guide authored
1 Guide Comment
Amigo, se você puder, poderia me ajudar? A minha massageadora está fazendo estava fazendo muito barulho. Quando abri a parte de baixo dourada, notei que a bateria ficava se mexendo pro lado e pro outro, e isso fazia muito barulho. Como eu posso arrumar isso?
kronos - Reply Share
Past 24 Hours: 3
Past 7 Days: 57
Past 30 Days: 250
All Time: 2,265
