Introduction
Go to step 1 ↓
Here's a chip identification summary for the Meta Quest Pro headset and controller.
Check out our Meta Quest Pro teardown for more details.
Special thanks to community member CChin for his contribution!
Video Overview
This teardown is not a repair guide. To repair your Meta Quest Pro, use our service manual.
    1. Meta Quest Pro Chip ID, Headset Mainboard Side A: step 1, image 1 of 1
      Ask FixBot
    2. Meta Quest Pro Chip ID: step 2, image 1 of 1
      • Infineon CYPD3177 USB Type-C Port Controller
      • Qualcomm SMB1355 Li-Ion Battery Charger w/ Quick Charge 2.0/3.0/5.0
      • Qualcomm PM3003A Power Management
      • Texas Instruments TLC59401 16-Ch. LED Driver
      • Texas Instruments TS3USB221 USB 2.0 SPDT Analog Switch
      • Awinic AW37504CSR ? Dual Output Power Supply
      • Analog Devices MAX77827B 1.6 A Buck Boost Converter
      Ask FixBot
    3. Meta Quest Pro Chip ID: step 3, image 1 of 1
      • Texas Instruments TPS62148 2.0 A step-down converter
      • Texas Instruments TPS61378-Q1 4.8 A synchronous boost converter
      • SG Micro SGM66056 2.2 MHz synchronous boost converter
      • OmniVision WS4694C 28 V over-voltage & over-current protection load switch
      • SG Micro SGM2578AAD 2 A load switch
      • Texas Instruments TLV7031 single comparator
      • Texas Instruments TLV9054 quad 5-MHz rail-to-rail operational amplifier
      Ask FixBot
    4. Meta Quest Pro Chip ID: step 4, image 1 of 1
      Ask FixBot
    5. Meta Quest Pro Chip ID: step 5, image 1 of 1
      • onsemi FSA4480UCX USB Type-C analog switch
      • SG Micro SGM4553 2-bit bidirectional voltage-level translator
      • OmniVision DPDT analog switch (possibly)
      Ask FixBot
    6. Meta Quest Pro Chip ID, Headset Mainboard Side B: step 6, image 1 of 1
      • Murata LBEE5xx1WK ? type 1WK Bluetooth/WiFi module
      • Nordic Semiconductor nRF52840 Bluetooth 5.3 low-energy SoC
      • Qualcomm PM8250 power management
      • Qualcomm PM8150B power management
      • Qualcomm PMK8002 ? clock generator
      • Texas Instruments TCA6418E 18-bit I/O expander
      • Renesas SLG59M1717V 5 A load switch
      Ask FixBot
    7. Meta Quest Pro Chip ID: step 7, image 1 of 1
      • Likely Texas Instruments LP5907UVE-1.2 250 mA / 1.2 V LDO regulator
      • DC-DC converter
      Ask FixBot
    8. Meta Quest Pro Chip ID, Headset Mainboard Side B - Sensors: step 8, image 1 of 1
      • Bosch Sensortec BMM150 3-axis magnetometer
      Ask FixBot
    9. Meta Quest Pro Chip ID, Controller Mainboard Side A: step 9, image 1 of 2 Meta Quest Pro Chip ID, Controller Mainboard Side A: step 9, image 2 of 2
      • Qualcomm SM6115 Snapdragon 662 Octa-Core applications/baseband processor
      • Samsung K4U8E3S4AD-MGCL 1 GB LPDDR4X SDRAM memory
      • Samsung KLM4G1FETE-B041 4 GB eMMC NAND flash memory
      • Qualcomm PMI632 power management
      • Microchip ATSAMD20G17 32-bit microcontroller
      • Renesas DA7281 haptic driver
      • Texas Instruments SN74AUC1G32 single 2-input OR gate
      Ask FixBot
    10. Meta Quest Pro Chip ID: step 10, image 1 of 1
      • Nexperia PUSB3FR4 4 ch. ESD protection
      Ask FixBot
    11. Meta Quest Pro Chip ID, Controller Mainboard Side A - Sensors: step 11, image 1 of 1
      • TDK-InvenSense ICM-42686-P 6-axis accelerometer & gyroscope
      • Allegro MicroSystems A1392 hall effect sensor
      • Allegro MicroSystems A1395 hall effect sensor
      Ask FixBot
    12. Meta Quest Pro Chip ID, Controller Mainboard Side B: step 12, image 1 of 2 Meta Quest Pro Chip ID, Controller Mainboard Side B: step 12, image 2 of 2
      • Qualcomm PM4250 power management
      • Cirrus Logic CS40L25 haptic driver
      • Nexperia 74LV1T34 single translating buffer
      • Nexperia 74LV1T04 single translating inverter
      Ask FixBot
    13. Meta Quest Pro Chip ID, Controller Mainboard Side B - Radio: step 13, image 1 of 1
      • Nordic Semiconductor nRF52832 Bluetooth Low-Energy 5.3 SoC
      • Skyworks SKY66111-11 Bluetooth Low Energy front-end module
      • Probably Qorvo QPC8019Q DPDT RF switch
      • Qualcomm WCN3950 WLAN 802.11a/b/g/n/ac, Bluetooth 5.0, & FM radio
      Ask FixBot
    14. Meta Quest Pro Chip ID, Controller Mainboard Side B - Sensors: step 14, image 1 of 1
      • Allegro MicroSystems A1391 hall effect sensor
      Ask FixBot
    15. Meta Quest Pro Chip ID, Console Accelerometer Board: step 15, image 1 of 1
      • TDK-InvenSense ICM-42688-P 6-axis MEMS accelerometer & gyroscope
      Ask FixBot
    16. Meta Quest Pro Chip ID, Headset Mainboard Side B: step 16, image 1 of 1
      • Cmedia CM7120 Audio DSP & CODEC Hub
      • Analog Devices MAX98360A Class-D Audio Amplifier
      • Qualcomm SMB1355 Battery Charger
      Ask FixBot
    17. Meta Quest Pro Chip ID, Headset Block Diagram: step 17, image 1 of 1
      • Predicted block diagram primarily based on available datasheets and observed implementation in product.
      Ask FixBot
    18. Meta Quest Pro Chip ID, Controller Block Diagram: step 18, image 1 of 1
      Ask FixBot
1 Guide Comment
Any photo-and-text-based teardown of the entire device like iFixit used to do? Love the company, but the fact that there aren't non-video articles on this under the Teardowns section is honestly a bit of a letdown. Would it be possible to bring them back? They're a really useful resource.
f14trex - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 160
All Time: 15,758
