This teardown is not a repair guide. To repair your Mouse, use our service manual.
  1. Mechanical Mouse Teardown, Mechanical Mouse Teardown: step 1, image 1 of 3 Mechanical Mouse Teardown, Mechanical Mouse Teardown: step 1, image 2 of 3 Mechanical Mouse Teardown, Mechanical Mouse Teardown: step 1, image 3 of 3
    • Rotate mouse over and locate Trackball cover
    • Using index fingers and thumb, rotate counter-clockwise
    Ask FixBot
  2. Mechanical Mouse Teardown: step 2, image 1 of 3 Mechanical Mouse Teardown: step 2, image 2 of 3 Mechanical Mouse Teardown: step 2, image 3 of 3
    • After the Trackball cover has been rotated, pry the lid off using fingernails.
    • Remove Trackball cover and place to the side.
    • Angle mouse to eject Trackball from the casing.
    Ask FixBot
  3. Mechanical Mouse Teardown: step 3, image 1 of 3 Mechanical Mouse Teardown: step 3, image 2 of 3 Mechanical Mouse Teardown: step 3, image 3 of 3
    • Using a Phillips head screwdriver, locate screw hole and unscrew the screw inside.
    • Lift the two cases apart and place screw to the side.
    Ask FixBot
  4. Mechanical Mouse Teardown: step 4, image 1 of 3 Mechanical Mouse Teardown: step 4, image 2 of 3 Mechanical Mouse Teardown: step 4, image 3 of 3
    • Remove the wire from the plastic casing near the top of the mouse.
    • Lift up to remove the PCB which is attached to the mouse.
    • Place case to the side.
    Ask FixBot
  5. Mechanical Mouse Teardown: step 5, image 1 of 3 Mechanical Mouse Teardown: step 5, image 2 of 3 Mechanical Mouse Teardown: step 5, image 3 of 3
    • Locate where the wire is connected to the PCB via the white connection.
    • Pry the connections apart and place the cable to the side.
    Ask FixBot
Kevin Gingrich
180 Reputation
2 Guides authored
Cal Poly, Team 20-28, Maness Fall 2011 Member of Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Members
15 Guides authored
2 Guide Comments
Wow! Someone really worked hard on this guide. Kudos sir.
Tushar Varshney - Reply Share
Yes sir I won't know everything about the machine
mubarak wad gab tagel - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 101
All Time: 7,280
