This teardown is not a repair guide. To repair your Matrox TripleHead2Go Display Adapter, use our service manual.
  1. Matrox TripleHead2Go Display Adapter Teardown, Matrox TripleHead2Go Display Adapter Teardown: step 1, image 1 of 3 Matrox TripleHead2Go Display Adapter Teardown, Matrox TripleHead2Go Display Adapter Teardown: step 1, image 2 of 3 Matrox TripleHead2Go Display Adapter Teardown, Matrox TripleHead2Go Display Adapter Teardown: step 1, image 3 of 3
    • The first step is to unscrew all screws.
    • Second one is to insert something at the shown edge pull gently but firmly apart, alternating sides.
    • At the end, it will come off sideways.
    • It will be full of tiny copper pieces. Actually they won't be where you see them in the picture, but pulled off and laying around. You will need them to reassembly.
    Ask FixBot
  2. Matrox TripleHead2Go Display Adapter Teardown, The card at daylight: step 2, image 1 of 2 Matrox TripleHead2Go Display Adapter Teardown, The card at daylight: step 2, image 2 of 2
    • This is how the card looks. Well made, isn't it?
    • If you turn it around, you will see on two chips the heat dissipating creme. Maybe you want to change it.
    Ask FixBot
  3. Matrox TripleHead2Go Display Adapter Teardown, The other way round: step 3, image 1 of 1
    • To reassemble the card, just go the same way back. You can see the positions of the copper pieces in the previous step (I guessed them by the marks in the metal), and the one of the screws in the first step. Easy, isn't it?
    Ask FixBot
leon
142 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 36
All Time: 595
