This teardown is not a repair guide. To repair your Makerbot Digitizer, use our service manual.
  1. Makerbot Digitizer Teardown, Remove rear screws and face plate: step 1, image 1 of 3 Makerbot Digitizer Teardown, Remove rear screws and face plate: step 1, image 2 of 3 Makerbot Digitizer Teardown, Remove rear screws and face plate: step 1, image 3 of 3
    • There are four black T15 screws that hold the front panel on.
    • Do not confuse these with the two laser adjustment screws.
    • The ones you need to loosen are perpendicular with the frame; not angled.
    • Once the screws are loosened, the front panel simply pulls off.
    Ask FixBot
  2. Makerbot Digitizer Teardown, Remove turntable: step 2, image 1 of 3 Makerbot Digitizer Teardown, Remove turntable: step 2, image 2 of 3 Makerbot Digitizer Teardown, Remove turntable: step 2, image 3 of 3
    • Pop the cap out with a flat pry tool.
    • Loosen the T15 screw. You don't need to remove it.
    • Pry on both sides of the turntable so that it comes up and out.
    • To reinstall it, make sure the motor-facing side goes in first, to make good contact with the stepper motor gear teeth.
    • If the stepper motor-facing side does not get reinstalled first, the table will not sit properly.
    Ask FixBot
  3. Makerbot Digitizer Teardown, Remove top panel: step 3, image 1 of 2 Makerbot Digitizer Teardown, Remove top panel: step 3, image 2 of 2
    • There are eight T15 screws holding the top panel in place.
    • Once these are all loosened, the top panel simply lifts off.
    • Your electronics will look different than mine. Everything should now be accessible.
    Ask FixBot
  4. Makerbot Digitizer Teardown, Inspect the stepper motor: step 4, image 1 of 1
    • Mine is a 'Moons 14HK2401-74N'.
    • The '74N' seems to indicate the voltage required, in this case, 12V.
    Ask FixBot
Job McKee
241 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 41
All Time: 545
