Up to 20% off select tools
Introduction
Go to step 1 ↓
Here you'll find chip ID information for the Mac mini (2024). Check out our Mac mini (2024) teardown for more details.
Special thanks to our community member Chunglin Chin for contributing to this guide!
This teardown is not a repair guide. To repair your Mac mini (2024), use our service manual.
    1. Mac Mini (2024) Chip ID, Main Board Side 1: step 1, image 1 of 2 Mac Mini (2024) Chip ID, Main Board Side 1: step 1, image 2 of 2
      • Apple APL1206/339S01548 E M4 deca-core applications processor w/ GPU
      • Micron MT62F1G64D4AS-026 XT:C 8 GB LPDDR5 SDRAM Memory
      • Apple APL1066/343S00710 power management
      • Apple APL1067/343S00683 ? power management
      • Likely Apple U0P4F7-Y2 Thunderbolt 4 controller
      • Winbond W25Q64NE 8 MB serial NOR flash memory
      • Likely Infineon CYUSB2408 USB level shifter
      Ask FixBot
    2. Mac Mini (2024) Chip ID, Main Board Side 1: step 2, image 1 of 1
      • Winbond W25X40CL 4 Mb serial NOR flash memory
      • Texas Instruments TPS628502 2 A / adj. step-down converter
      • Analog Devices DC-DC converter
      • Texas Instruments TPS715A01 80 mA / adj. LDO regulator
      • Texas Instruments TPS2559 power distribution switch
      • Texas Instruments INA190A2 bidirectional current sense amplifier
      • Texas Instruments TLV7021 single comparator
      Ask FixBot
    3. Mac Mini (2024) Chip ID: step 3, image 1 of 2 Mac Mini (2024) Chip ID: step 3, image 2 of 2
      • Likely Parade Technologies PS190 DisplayPort to HDMI converter
      • Genesys Logic GL3590-TBYS2 3 USB Type-C SuperSpeed+ & 3 USB Type-A SuperSpeed+ hub controller
      • Macronix MX25V2035FZUI 2 Mb serial NOR flash memory
      • Texas Instruments SN26A23 USB Type-C controller
      • GigaDevice GD25Q80E 1 MB serial NOR flash memory
      • Broadcom BCM57762 gigabit ethernet controller
      Ask FixBot
    4. Mac Mini (2024) Chip ID: step 4, image 1 of 1
      • Apple APL5791/343S00709 power management
      • Renesas multiphase controller
      • Cirrus Logic CS42L84A audio codec
      • Texas Instruments SN012776B0 audio amplifier
      • Texas Instruments TPS621371 step-down converter
      • Likely Renesas PWM DC-DC converter controller
      Ask FixBot
    5. Mac Mini (2024) Chip ID: step 5, image 1 of 1
      • onsemi NCP380LMU05AATBG power distribution switch
      • Likely Renesas mixed signal array
      • Texas Instruments TLV75801P 500 mA / adj. LDO regulator
      • Texas Instruments INA190A3 bidirectional current sense amplifier
      • Texas Instruments TLV7011 single comparator
      • Texas Instruments TLV9051 single operational amplifier
      Ask FixBot
    6. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 1: step 6, image 1 of 2 Mac Mini (2024) Chip ID, Flash Module (NAND) Side 1: step 6, image 2 of 2
      • SanDisk SDMVGKLK2 128G 128 GB NAND flash
      Ask FixBot
    7. Mac Mini (2024) Chip ID, Flash Module (NAND) Side 2: step 7, image 1 of 2 Mac Mini (2024) Chip ID, Flash Module (NAND) Side 2: step 7, image 2 of 2
      • Apple 338S00600-A0 power management
      • Texas Instruments TPS62180 6 A synchronous buck converter
      Ask FixBot
    8. Mac Mini (2024) Chip ID, Wireless Board: step 8, image 1 of 2 Mac Mini (2024) Chip ID, Wireless Board: step 8, image 2 of 2
      • Likely USI 339S01162 Bluetooth & WiFi module
      Ask FixBot
0 Guide Comments
Past 24 Hours: 16
Past 7 Days: 149
Past 30 Days: 696
All Time: 19,069
