This teardown is not a repair guide. To repair your Logitech M650 L, use our service manual.
    1. Logitech M650 L  Mouse Teardown, The Start: step 1, image 1 of 1
      • Remove the back plate and the battery with the receiver
      Ask FixBot
    2. Logitech M650 L  Mouse Teardown, The Start: step 2, image 1 of 3 Logitech M650 L  Mouse Teardown, The Start: step 2, image 2 of 3 Logitech M650 L  Mouse Teardown, The Start: step 2, image 3 of 3
      • Use your Phillips 00 screwdriver to unscrew the 2 screws as shown in the image. Be careful when removing the bottom part of the mouse because there is a cable you have to disconnect.
      Ask FixBot
    3. Logitech M650 L  Mouse Teardown, Bottom Part: step 3, image 1 of 3 Logitech M650 L  Mouse Teardown, Bottom Part: step 3, image 2 of 3 Logitech M650 L  Mouse Teardown, Bottom Part: step 3, image 3 of 3
      • Using your Phillips 000 screwdriver or bit, unscrew the 2 screws holding down the scroll wheel.
      Ask FixBot
    4. Logitech M650 L  Mouse Teardown, The Bottom: step 4, image 1 of 3 Logitech M650 L  Mouse Teardown, The Bottom: step 4, image 2 of 3 Logitech M650 L  Mouse Teardown, The Bottom: step 4, image 3 of 3
      • Now, using the same bit, unscrew the 2 screws holding the board down.
      Ask FixBot
    5. Logitech M650 L  Mouse Teardown, The Top: step 5, image 1 of 1
      • Now, on the top side of the mouse, you're going unscrew the screw at the back
      Ask FixBot
    6. Logitech M650 L  Mouse Teardown, The Top: step 6, image 1 of 1
      • Next, you're going to use your Phillips 00 screwdriver or bit and unscrew the screw on the tiny board.
      Ask FixBot
    7. Logitech M650 L  Mouse Teardown, The Top: step 7, image 1 of 2 Logitech M650 L  Mouse Teardown, The Top: step 7, image 2 of 2
      • Now using a spudger or your hand, your going to pull and pry at the back of the mouse to remove the upper layer
      Ask FixBot
    8. Logitech M650 L  Mouse Teardown, The Tiny Board: step 8, image 1 of 3 Logitech M650 L  Mouse Teardown, The Tiny Board: step 8, image 2 of 3 Logitech M650 L  Mouse Teardown, The Tiny Board: step 8, image 3 of 3
      • Finally you can remove the tiny board. First remove the cable, then pull up on the cable to remove the board
      Ask FixBot
    9. Logitech M650 L  Mouse Teardown, You're Done!!!: step 9, image 1 of 1
      • Hooray! You're done. Now put it back together.
      Ask FixBot
Benjamin
169 Reputation
1 Guide authored
1 Guide Comment
정말 잘 보고 갑니다. 덕분에 분해 잘했습니다😁
NightFox - Reply Share
Past 24 Hours: 6
Past 7 Days: 46
Past 30 Days: 193
All Time: 3,451
