This teardown is not a repair guide. To repair your Logitech M Series Mouse, use our service manual.
    1. Logitech M235 Teardown, Logitech M235 Teardown: step 1, image 1 of 1
      • Remove the battery and battery cover
      Ask FixBot
    2. Logitech M235 Teardown: step 2, image 1 of 2 Logitech M235 Teardown: step 2, image 2 of 2
      • Remove the the two screws holding the cover.
      • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
      Ask FixBot
    3. Logitech M235 Teardown: step 3, image 1 of 1
      • Use a prying tool to split the mouse case apart.
      Ask FixBot
    4. Logitech M235 Teardown: step 4, image 1 of 1
      • The case should be easy to open and not require much force.
      Ask FixBot
    5. Logitech M235 Teardown: step 5, image 1 of 1
      • The PCB is only held by a few clips and can be easily removed.
      Ask FixBot
    6. Logitech M235 Teardown: step 6, image 1 of 1
      • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
      Ask FixBot
    7. Logitech M235 Teardown: step 7, image 1 of 1
      • Done!
      Ask FixBot
Daniel
225 Reputation
1 Guide authored
4Bits Repairs Member of 4Bits Repairs
Business
1 Member
12 Guides authored
8 Guide Comments
Great work. Hope to see some more of your work
Mustafa karu - Reply Share
thank you..this helped me a looot
Sharnav Kundu - Reply Share
My M325 has NO SCREWS!!! Now what???
christcansaveyou - Reply Share
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - Reply Share
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 128
All Time: 23,874
