This teardown is not a repair guide. To repair your Logitech K700 Keyboard, use our service manual.
  1. Logitech K700 Keyboard Teardown, Logitech K700 Keyboard Teardown: step 1, image 1 of 1
    • Turn the keyboard over and slide the battery cover in the direction of the arrows slightly, and then lift the cover away.
  2. Logitech K700 Keyboard Teardown: step 2, image 1 of 1
    • Remove the batteries and the two screws shown.
  3. Logitech K700 Keyboard Teardown: step 3, image 1 of 1
    • Use a thumbnail or a pick to separate the clips around the periphery between the black and white plastic parts.
    • There are 4 clips on the top, 2 on either side, and 5 along the bottom. If you do the sides and top first, the bottom should slide out.
    • Don't separate the top and bottom immediately, since there are a couple of cables (near the touch pad) that connect between the two.
  4. Logitech K700 Keyboard Teardown: step 4, image 1 of 1
    • The smaller of the two cables is for the touchpad. Lift the catch on its connector in order to slide it out.
    • The larger cable is for the key matrix. Just pull it out from the connector (friction fit).
    • This is as far as you can easily disassemble the keyboard. To go further requires removing 12 screws and 35 plastic rivets. This is not recommended.
    • To clean the keyboard of liquid, I suggest holding it over a sink with the touchpad side up, then spraying plenty of isopropyl alcohol from the back, avoiding the touch-pad area (you may wish to mask it off). Let dry completely before reassembling.
    • If keys still do not function after cleaning, then it is possible that traces on the key matrix have become corroded. This is not repairable, since the key matrix is a sealed unit. It consists of 3 layers of plastic that are sealed together. Unfortunately, it is not 100% sealed to prevent entry of liquids.
  5. Logitech K700 Keyboard Teardown: step 5, image 1 of 1
    • Should you go further and remove the 12 screws and 35 plastic rivets, you can see this.
  6. Logitech K700 Keyboard Teardown: step 6, image 1 of 1
    • The keys can be popped out easily enough by pushing from the back side. This exposes the key matrix.
  7. Logitech K700 Keyboard Teardown: step 7, image 1 of 1
    • Here is the key matrix in all its glory.
cityzen
4,117 Reputation
2 Guides authored
3 Guide Comments
Very helpful! I combined this and cleaning the battery compartments with a white vinegar drenched Q-Tip to clean out some old battery corrosion, and now it turns on!
mpeterfin - Reply Share
any way you could send me a pic of the backside of the battery cover? i’d like to try to recreate it with a 3d printer
Cody Nelson - Reply Share
codycnelson@gmail.com :)
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 80
All Time: 17,086
