This teardown is not a repair guide. To repair your Logitech Circle, use our service manual.
  1. Logitech Circle Teardown, Not a Single Screw in Sight!: step 1, image 1 of 2 Logitech Circle Teardown, Not a Single Screw in Sight!: step 1, image 2 of 2
    • The Circle camera has no external screws. The first step to get in requires a plastic spludger: the dark colored ring is held on with double sticky tape.
    • Note: the ring is made of infrared transparent plastic, and includes lenses to help direct the night vision LEDs.
    Ask FixBot
  2. Logitech Circle Teardown, A Peek Inside: step 2, image 1 of 1
    • It's all screws from this point out: a lot of them. Consider using bags to hold groups of screws together for reassembly.
    • Unscrew the four screws circled in order to remove the first ring.
    Ask FixBot
  3. Logitech Circle Teardown: step 3, image 1 of 1
    • Remove the next ring by continuing to unscrew the screws in the circled locations.
    Ask FixBot
  4. Logitech Circle Teardown: step 4, image 1 of 2 Logitech Circle Teardown: step 4, image 2 of 2
    • Finally, remove the last set of screws to access the inner parts of the circle.
    • Gently pull out the lens/battery assemble -- it's attached to a flexible ribbon cable that can rip, so be especially careful.
    Ask FixBot
  5. Logitech Circle Teardown, Inside the Ball: step 5, image 1 of 2 Logitech Circle Teardown, Inside the Ball: step 5, image 2 of 2
    • Take care not to damage the flexible cable. On the connector, flip up the black plastic cam to release the cable. You can then remove the camera / battery assembly from the ball.
    • Note the extensive use of heat sinks and thermal interface (TIM) materials. This camera is delicately balanced thermally.
    Ask FixBot
  6. Logitech Circle Teardown, Hidden USB Connector: step 6, image 1 of 3 Logitech Circle Teardown, Hidden USB Connector: step 6, image 2 of 3 Logitech Circle Teardown, Hidden USB Connector: step 6, image 3 of 3
    • Ho! What's that? Under a soft spot in the base is a hidden USB connector, presumably used for firmware loading in production.
    • To disassemble the base find 3 screws under the soft spot, punch through using a screwdriver, and remove the screws. After that both parts can be easily separated.
    Ask FixBot
  7. Logitech Circle Teardown, Optical Chain: step 7, image 1 of 2 Logitech Circle Teardown, Optical Chain: step 7, image 2 of 2
    • The outer ring has lenses to focus IR light, and a hole for the camera lens.
    • The six infrared LEDs are on a thick board, with an aluminum heat spreader, and a connection to two solid metal blocks attached to the sensor board.
    • The lens is manually focused and secured with what looks like hot melt glue (this may cause focus issues over time).
    • There is just one piece of filter glass, flipped in place for day mode (higher end cameras use separate glass for day and night mode).
    • The optical sensor is at the bottom of the stack. It's surrounded by a clear plastic sticker (if you know why, post in the comments!).
    Ask FixBot
Bryce Nesbitt
1,244 Reputation
8 Guides authored
25 Guide Comments
any ideas where get a replacement ribbon cable? I dropped the camera when opening the box and the base and camera separated (ribbon cable tore). I was able to disassemble with this guide, but now I need a new cable and Logitech is no help (I asked).
Thanks
David
David Ludder - Reply Share
We just had it fall off the table it was on and it did exactly the same thing... the base and camera separated (ribbon cable tore).
bradowenco - Reply Share
I emailed the manufacturer of the cable to see if they can help, will let you know if they answer.
any word from them?
Nothing yet, I'll have to send another email.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 49
All Time: 10,577
