This teardown is not a repair guide. To repair your Kobo Forma, use our service manual.
  1. Kobo Forma Teardown, Remove Fingerplate: step 1, image 1 of 3 Kobo Forma Teardown, Remove Fingerplate: step 1, image 2 of 3 Kobo Forma Teardown, Remove Fingerplate: step 1, image 3 of 3
    • Careful: the fingerplate is glued down, and may not come off easily. Work slowly and use heat to soften the adhesive if needed, otherwise it can break off in pieces.
    • Remove the finger plate. Start in one corner and push in a spudger/flat blade and lever it up. It is glued all the way along and has clips at the bottom edge so you'll want to bend out the bottom edge to clear the clips.
    Ask FixBot
  2. Kobo Forma Teardown, Remove the back cover: step 2, image 1 of 3 Kobo Forma Teardown, Remove the back cover: step 2, image 2 of 3 Kobo Forma Teardown, Remove the back cover: step 2, image 3 of 3
    • With the fingerplate removed, you can get a spugder in the bottom and lever off the backplate. Again it is stuck down with tape all the way round and has clips that break away easily. I don't suggest you do like I did and push a metal screwdriver all the way in, you could short out the battery. It is coated with some glue/lacquer, so maybe not!
    Ask FixBot
  3. Kobo Forma Teardown, Remove battery & mainboard: step 3, image 1 of 3 Kobo Forma Teardown, Remove battery & mainboard: step 3, image 2 of 3 Kobo Forma Teardown, Remove battery & mainboard: step 3, image 3 of 3
    • The board is held down by some small (#0?) screws and the battery is stuck down with double sided tape. You will likely pierce the foil wrap when you try to remove it.
    Ask FixBot
Max Allan
105 Reputation
1 Guide authored
4 Guide Comments
I think my battery needs replacing. It won't hold a charge for long. Did you get your ereader to work again?
H. Koops - Reply Share
I think it should be noted that it is not necessary to remove the fingerplate to access the battery. It is possible to replace it by just removing the back cover.
Hermosilla - Reply Share
Hi @antonioher64178 - are you saying it is possible to remove the back cover without removing the fingerplate, and not cause any damage?
TIRTHA SARKAR - Reply Share
I found this video guide to remove the back cover , and replac e the battery - and by it (not my personal experience), it seems that indeed removing the fingerplate isn't necessary for back cover removal.
https://youtu.be/8_fHqVmo6ZM
Moshep - Reply Share
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 185
All Time: 4,686
