This teardown is not a repair guide. To repair your Synthesizers, use our service manual.
  1. KORG Volca Sample Teardown, Remove the screws on the bottom: step 1, image 1 of 2 KORG Volca Sample Teardown, Remove the screws on the bottom: step 1, image 2 of 2
    • Remove seven Screws.
    • Then turn the Volca around. You can now remove the two PCBs. Take care with the loudspeaker cable and the battery cable. In my picture the black cable is already loose.
    Ask FixBot
  2. KORG Volca Sample Teardown, The PCB with the knobs and the main logic: step 2, image 1 of 1
    • This is the main processor. It is an Cypress FM4-Series MB9BF164L.
    • 25Q03213
    • The DAC. AKM4384FT.
    • MV3241 / 49AG3 / P220
    Ask FixBot
  3. KORG Volca Sample Teardown, The PART, MUTE, FUNC, WRITE etc. buttons: step 3, image 1 of 2 KORG Volca Sample Teardown, The PART, MUTE, FUNC, WRITE etc. buttons: step 3, image 2 of 2
    • This is how working buttons should look like.
    • If this isn't the case, clean these parts with a Q-Tip dipped in isopropanol.
    • Clean these parts as well.
    Ask FixBot
  4. KORG Volca Sample Teardown: step 4, image 1 of 2 KORG Volca Sample Teardown: step 4, image 2 of 2
    • Here is a complete overview of the PCB containing the Step Touch Buttons and the FUNC and WRITE buttons
    Ask FixBot
Christian
1,655 Reputation
8 Guides authored
27 Guide Comments
Hello, thanks for this post. I have an issue with my volca sample, only sound left is outputting. can you show me where the audio jack output circuit is ? Would be much appreciated. I think it’s a spike made by my soundcard while turnung it on that caused this issue.
Orphée Design - Reply Share
Sorry, I can’t help you here. You may try www.korgforums.com. There are some discussions about broken Volcas.
Christian - Reply Share
Hi,
My Volca Sample LCD is dimmed (knob lights are not working too, however button lights works) after accidentally liquid spill. Everything else is fine. Can you give me some tip about dimmed LCD? Tnx
Flick Simpson - Reply Share
Hi, you can try open the Volca and rinse it thouroughly with distilled water. Remove the batteries before. Then dry it with a fan and keep it open and let it dry on air for 24 hours. The re-insert the batteries and hope for the best. What kind of liquid was it?
Hello!! I have an issue with my VS. The Button 7 keeps triggering without no reason and is a pain in the ass. I opened the VS and cleaned all the pads ans circuits but doesn´t seem to do anything. :(
rodtop350z - Reply Share
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 86
All Time: 9,213
