Introduction
Go to step 1 ↓Due to the interest on online forums for the chip ID of this device, here is IC Identifications of the HomePod Mini. Images are originally from an iFixit blog post.
Full IC Identifications can be downloaded above.
Featured Document
Side 1 IC Identification, Pt. 1:
Apple APL1W82 64-Bit Dual-Core Applications Processor w/ GPU with likely 1 Gb LPDDR3 SDRAM Memory
Apple 338S00553-A0 Power Management
Nordic Semiconductor nRF52833 Bluetooth 5.2 SoC w/ NFC and Zigbee
Skyworks SKY66404-11 2.4 GHz Zigbee/Thread/Bluetooth Front-End Module
USI 339M00117 WiFi/Bluetooth Module
USI UWB Transceiver
Side 1 IC Identification, Pt. 2:
Analog Devices SSM3582A 31.76 W Filterless Stereo Class D Audio Amplifier
Texas Instruments CD3217B12 USB Type C Controller
Winbond W25Q80DVUXIE 8 Mb Serial NOR Flash Memory
Texas Instruments TPS62130B 3 A Step Down Converter
Texas Instruments INA199C3DCK Bi-Directional Current Sense Amplifier
Dialog Semiconductor SLG46140 Programmable Mixed Signal Array
3 Likely Goertek MEMS Microphones are found around the perimeter of the PCB.
Side 2 IC Identification:
Texas Instruments LP5030RJVR 30-Ch. Constant Current RGB LED Driver
Texas Instruments TPS55340RTE 5 A Boost Regulator
Austria Microsystems (AMS) Ambient Light Sensor
Sensor Flex IC Identifications:
Texas Instruments HDC2010YPA Humidity/Temperature Sensor
Another likely Goertek MEMS Microphone
Attached Documents
3 Guide Comments
nRF52833 is used for Thread networking protocol. Refer to HomePod mini tech spec: https://www.apple.com/homepod-mini/specs...
Hello, does anyone have any idea about the specs of the 2R2 inductor near the Texas Instruments TPS62130B 3 A Step Down Converter? Bought a dead HomePod Mini online to try and fix. I noticed that this component was missing on the board. Thank you!
