Introduction
Go to step 1 ↓
In this guide you will learn how to teardown the HEC remote control
Tools
This teardown is not a repair guide. To repair your HEC Remote Control, use our service manual.
    1. HEC Remote Control Teardown, HEC Remote Control Teardown: step 1, image 1 of 2 HEC Remote Control Teardown, HEC Remote Control Teardown: step 1, image 2 of 2
      • Using a flat head screwdriver pry open the remote
      Ask FixBot
    2. HEC Remote Control Teardown: step 2, image 1 of 2 HEC Remote Control Teardown: step 2, image 2 of 2
      • Detach the circuit board from the bottom half of the remote casing.
      • Be careful when removing the circuit board from the casing.
      • Springs are attached to the remote casing
      Ask FixBot
    3. HEC Remote Control Teardown: step 3, image 1 of 1
      • Remove plastic molding attached to the top half of the remote casing
      Ask FixBot
    4. HEC Remote Control Teardown: step 4, image 1 of 1
      • Remove the lid encasing the batteries
      Ask FixBot
Travis Go
167 Reputation
2 Guides authored
Cal Poly, Team 17-15, Regan Fall 2011 Member of Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 44
All Time: 3,120
