This teardown is not a repair guide. To repair your Godox Litemons LED6R, use our service manual.
  1. Godox Litemons LED6R Teardown, Screws: step 1, image 1 of 3 Godox Litemons LED6R Teardown, Screws: step 1, image 2 of 3 Godox Litemons LED6R Teardown, Screws: step 1, image 3 of 3
    • Three PH0 screws
    Ask FixBot
  2. Godox Litemons LED6R Teardown, Opening: step 2, image 1 of 3 Godox Litemons LED6R Teardown, Opening: step 2, image 2 of 3 Godox Litemons LED6R Teardown, Opening: step 2, image 3 of 3
    • Pry the outer case out somewhat like this to release the clips
    Ask FixBot
  3. Godox Litemons LED6R Teardown, LED Panel: step 3, image 1 of 2 Godox Litemons LED6R Teardown, LED Panel: step 3, image 2 of 2
    • Insert wisdom here.
    Ask FixBot
  4. Godox Litemons LED6R Teardown, Screws from PCB: step 4, image 1 of 3 Godox Litemons LED6R Teardown, Screws from PCB: step 4, image 2 of 3 Godox Litemons LED6R Teardown, Screws from PCB: step 4, image 3 of 3
    • Under that foam block is another screw and there is probably one under the battery.
    • The battery is glued with another foam block to the PCB. The connections are soldered.
    • The details of the battery are covered by this glued foam block.
    Ask FixBot
  5. Godox Litemons LED6R Teardown, Additional pictures: step 5, image 1 of 2 Godox Litemons LED6R Teardown, Additional pictures: step 5, image 2 of 2
    • LED Panel in the case and the hot shoe adapter
    Ask FixBot
Quanten
1,315 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 39
All Time: 459
