Up to 20% off select tools
Introduction
Go to step 1 ↓
A wireless mouse made by Glorious Gaming
This teardown is not a repair guide. To repair your glorious Model 02 Pro, use our service manual.
    1. Glorious Model O2 Pro Teardown, Flip Over: step 1, image 1 of 2 Glorious Model O2 Pro Teardown, Flip Over: step 1, image 2 of 2
      • Turn the mouse to the bottom
      Ask FixBot
    2. Glorious Model O2 Pro Teardown, Remove feet: step 2, image 1 of 3 Glorious Model O2 Pro Teardown, Remove feet: step 2, image 2 of 3 Glorious Model O2 Pro Teardown, Remove feet: step 2, image 3 of 3
      • Remove top and bottom feet
      • Make sure to keep these and don't loose then
      Ask FixBot
    3. Glorious Model O2 Pro Teardown, Remove Screws: step 3, image 1 of 3 Glorious Model O2 Pro Teardown, Remove Screws: step 3, image 2 of 3 Glorious Model O2 Pro Teardown, Remove Screws: step 3, image 3 of 3
      • Use a PH001 Screwdriver to remove both screws
      Ask FixBot
    4. Glorious Model O2 Pro Teardown, Unclip Plastic Piece: step 4, image 1 of 3 Glorious Model O2 Pro Teardown, Unclip Plastic Piece: step 4, image 2 of 3 Glorious Model O2 Pro Teardown, Unclip Plastic Piece: step 4, image 3 of 3
      • (Ignore Bird Sticker)
      • Slide in an opening pick and gently wiggle across the plate
      Ask FixBot
    5. Glorious Model O2 Pro Teardown, Same as step 4: step 5, image 1 of 1
      • After undoing the last clip the playe should come off to reveal…. (Drum roll) More Clips!
      Ask FixBot
    6. Glorious Model O2 Pro Teardown, Remove Mouse Buttons: step 6, image 1 of 3 Glorious Model O2 Pro Teardown, Remove Mouse Buttons: step 6, image 2 of 3 Glorious Model O2 Pro Teardown, Remove Mouse Buttons: step 6, image 3 of 3
      • Insert a plastic spudger through the clips
      Ask FixBot
    7. Glorious Model O2 Pro Teardown, Unscew: step 7, image 1 of 3 Glorious Model O2 Pro Teardown, Unscew: step 7, image 2 of 3 Glorious Model O2 Pro Teardown, Unscew: step 7, image 3 of 3
      • Make sure to get the 4th one that is horizontally straight from the other top screw
      • Keep these screws separate from the ones from the start these 4 are slightly smaller
      Ask FixBot
    8. Glorious Model O2 Pro Teardown, Remove Inner shell: step 8, image 1 of 3 Glorious Model O2 Pro Teardown, Remove Inner shell: step 8, image 2 of 3 Glorious Model O2 Pro Teardown, Remove Inner shell: step 8, image 3 of 3
      • Do a combination of using the puck and prying with your hands use caution because the motherboard and battery cables can be damaged
      Ask FixBot
    9. Glorious Model O2 Pro Teardown, Remove housing: step 9, image 1 of 2 Glorious Model O2 Pro Teardown, Remove housing: step 9, image 2 of 2
      • Lift it from the housing
      Ask FixBot
    10. Glorious Model O2 Pro Teardown, Unplug battery: step 10, image 1 of 2 Glorious Model O2 Pro Teardown, Unplug battery: step 10, image 2 of 2
      • Unplug the JST connector from the lipo-cell battery
      Ask FixBot
    11. Glorious Model O2 Pro Teardown, Remove mainboard: step 11, image 1 of 2 Glorious Model O2 Pro Teardown, Remove mainboard: step 11, image 2 of 2
      • Unscew the 3 smaller screws then remove mainboard from housing
      • Thanks for reading my first ifixit guide (R.I.P my prying puck)
      Ask FixBot
Author
with
0DanDan0
274 Reputation
1 Guide authored
4 Guide Comments
They removed the last photo with all the pieces 😭
0DanDan0 - Reply Share
can you send me the photo with all the pieces?
Fok Pop - Reply Share
Dont think i can...
Hey! What is the battery model? I am buying a replacement battery
Đặng Thiên Ân - Reply Share
Past 24 Hours: 9
Past 7 Days: 41
Past 30 Days: 195
All Time: 3,412
