This teardown is not a repair guide. To repair your Fitbit One, use our service manual.
    1. Fitbit One Teardown, Fitbit One Teardown: step 1, image 1 of 2 Fitbit One Teardown, Fitbit One Teardown: step 1, image 2 of 2
      • Removing the metal backplate is simple. This is just stuck on with some flexible glue. So prise something under and off it pops.
      • Inside you can see a number of large cut outs in the rear of the plastic casing.
      • Note the small pinhole in the metal backplate that aligns with the rubber sealed hole in the plastic casing - more on that later.
      • There is also a very small ground out area inside the metal backplate that appears to align with the rotating mass of the vibrator.
      Ask FixBot
    2. Fitbit One Teardown: step 2, image 1 of 2 Fitbit One Teardown: step 2, image 2 of 2
      • The plastic casing is made up of two parts stuck together. Using a precision utility knife, carefully cut along the seam.
      • There are plastic clips at each end that are easy to cut through inadvertently if you go too deep.
      • The front now lifts away cleanly.
      Ask FixBot
    3. Fitbit One Teardown: step 3, image 1 of 2 Fitbit One Teardown: step 3, image 2 of 2
      • Inside the front cover you see the LCD display, attached by ribbon cable and stuck firmly onto the PCB.
      • Above the display, running down the right hand side of the device front, is the BLE antenna.
      • Lifting the LCD glass just results in destroying it, and there is nothing interesting underneath anyway.
      Ask FixBot
    4. Fitbit One Teardown: step 4, image 1 of 2 Fitbit One Teardown: step 4, image 2 of 2
      • The PCB lifts out from the back of the plastic housing easily.
      • Notice how the battery is supported on stand-offs from the rear of the PCB.
      • The battery is held in place with a small foam block adhering to the battery and PCB. Cut that away and the battery lifts off.
      Ask FixBot
    5. Fitbit One Teardown: step 5, image 1 of 2 Fitbit One Teardown: step 5, image 2 of 2
      • Now we get to see some more interesting parts.
      • The SoC has a QR code sticker, likely for inventory control, so take that off to see what we have underneath.
      • You can also see the spring-loaded paddles at the bottom of the PCB that connect to the device charging pins.
      • The power control module for the battery is wrapped up near the battery terminals.
      Ask FixBot
    6. Fitbit One Teardown: step 6, image 1 of 2 Fitbit One Teardown: step 6, image 2 of 2
      Ask FixBot
    7. Fitbit One Teardown: step 7, image 1 of 2 Fitbit One Teardown: step 7, image 2 of 2
      • The air pressure hole, required for the altimeter, is protected by a piece of paper held in place by a foam collar.
      • In turn, the inside of the plastic cover presses onto a foam collar around the altimeter on the PCB.
      • This makes the device sweat proof, but not water tight.
      Ask FixBot
    8. Fitbit One Teardown: step 8, image 1 of 1
      • Too bad the display was damaged during teardown.
      • Looks like a tidy, well-designed bit of tech!
      • Conclusion is that the FitBit One is not an easily repairable device.
      • The device is not designed to be opened, so you will do some damage by cutting it open
      • Taking things apart will compromise the water resistance of the device, and the LCD display is easily broken by any flexing or attempts to modify.
      Ask FixBot
Tim Ellison
231 Reputation
1 Guide authored
27 Guide Comments
Are there any markings indicating the controller interface for the LED display? Its a nice display, and I'd be curious if the module in my broken Fitbit could be repurposed.
Andrew Villeneuve - Reply Share
My Fitbit went through the clothes washer attached to my jeans. When it came out I was amazed it was still working, but after 2 days the display went blank, and it was dead to the world. I tried unsuccesfully to dry it out in rice for a week, but that didn't help at all. I then took the decision to carefully open it as in this guide. I found quite a lot of sulphate corrosion at various places on the board, plus some water droplets inside the case. I cleaned the board with an ear bud dipped in methylated spirits to remove the corrosion, and I dried the water drops carefully with hair dryer. After gluing it together, and charging, it is working perfectly again - I guess not as water tight as before, but I can live with that - so long as it doesn't go through the washer again :P
wayne - Reply Share
What type of glue did you use?
Vonda K Robb - Reply Share
Could anyone tell me what kind of tools I should use to remove the metal back? I spent some time but did not work it out. Thanks.
Elias - Reply Share
My Fitbit One fell face down during a wintry mix and drizzle and when I found it, it wasn't working. I put it in a bag of rice for a few hours but it didn't work. I opened it up and everything was remarkably clean and dry, but so far no success in resuscitation!
Chris - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 129
All Time: 66,769
