This teardown is not a repair guide. To repair your Fitbit Flex, use our service manual.
    1. Fitbit Flex Teardown, Fitbit Flex Teardown: step 1, image 1 of 3 Fitbit Flex Teardown, Fitbit Flex Teardown: step 1, image 2 of 3 Fitbit Flex Teardown, Fitbit Flex Teardown: step 1, image 3 of 3
      • So many goodies in one package! The Fitbit Flex comes with the following:
      • Two adjustable wristbands: one large, one small
      • Wireless sync dongle
      • Charging cable
      • The Flex tracker sports some cool tech specs, too.
      • Bluetooth 4.0 syncing
      • Memory to store 30 days of data
      • 5-day battery life
      Ask FixBot
    2. Fitbit Flex Teardown: step 2, image 1 of 3 Fitbit Flex Teardown: step 2, image 2 of 3 Fitbit Flex Teardown: step 2, image 3 of 3
      • With less effort than peeling an orange, we peel the Fitbit Flex tracker out of the flexible wrist strap.
      • Although it seems like a small consideration, we appreciate how easy it is to separate the electronics from the wrist strap—the component most likely to wear out.
      Ask FixBot
    3. Fitbit Flex Teardown: step 3, image 1 of 2 Fitbit Flex Teardown: step 3, image 2 of 2
      • Normally we would compare the device to other similar devices. Unfortunately, we don't really have much to compare the Flex to. How about a half dollar?
      • The Flex may be slightly larger than a half dollar (though smaller than half a dollar bill), but it will cost you 200 of them.
      • If anyone pays for a Fitbit Flex with half dollars, we would love to hear about it.
      • The back of the Flex reveals the model number, FB401, and provides a nice insertion arrow. It's not quite disassembly information, but it's something, right?
      Ask FixBot
    4. Fitbit Flex Teardown: step 4, image 1 of 3 Fitbit Flex Teardown: step 4, image 2 of 3 Fitbit Flex Teardown: step 4, image 3 of 3
      • The first things we notice on the Flex are the waterproof contacts. This is good news for those who might be sweating while wearing, or tearing down, the Flex.
      • For the record, the Flex claims to be water-tight up to 10 meters, or 264 simultaneous Gatorade showers.
      • This tiny gizmo fits snugly in its USB charger when its lithium-polymer battery needs juice.
      • Not to worry, it won't take the place of your smartphone on the charger each night—this little gadget has a reported battery life of 5 days.
      Ask FixBot
    5. Fitbit Flex Teardown: step 5, image 1 of 2 Fitbit Flex Teardown: step 5, image 2 of 2
      • With no visible point of entry, we figure the path to victory can be carved with judicious application of sharp tools.
      • Around here, we're big fans of Dozuki. We're also big fans of dozukis. When saw comes to gadget, you know it's a teardown.
      • Remember that teardowns are for fun and should not be followed as disassembly instructions. Please do not cut into your device with a dozuki.
      Ask FixBot
    6. Fitbit Flex Teardown: step 6, image 1 of 3 Fitbit Flex Teardown: step 6, image 2 of 3 Fitbit Flex Teardown: step 6, image 3 of 3
      • Our first extraction: the light guides for the LEDs that pass for a display on this slim, dare we say emaciated, unit.
      • Next out is the Bluetooth antenna, used for communicating with devices and the accompanying dongle.
      • Oops! We appear to have a tiny hitchhiker; that's a piece of the motherboard hanging on to the antenna.
      • To those of you following along at home: you don't need to chop up your PCB.
      • P.S. Don't follow along at home.
      Ask FixBot
    7. Fitbit Flex Teardown: step 7, image 1 of 2 Fitbit Flex Teardown: step 7, image 2 of 2
      • Pulling components out through the top of the Flex worked for a little while, but it's time to get to the good stuff.
      • Using our handy rotary tool, we cut through the plastic casing of the Flex tracker.
      • Well hello there, Rico Suave! Peeling back the Flex's stylish plastic jacket reveals the components we've been looking for.
      • Repairability update: This little guy is never, ever, ever going back together.
      Ask FixBot
    8. Fitbit Flex Teardown: step 8, image 1 of 3 Fitbit Flex Teardown: step 8, image 2 of 3 Fitbit Flex Teardown: step 8, image 3 of 3
      • The main board slides right away from the contact pins. Now we can get to the juicy bits.
      • Small and encased in a thin sheet of metal tape, the battery is soldered to the motherboard. By this point, a replaceable battery is the least of our worries.
      • We're getting some good vibrations from the prominent vibrator that functions as an alarm.
      Ask FixBot
      • This is how your vibrator works in your Fitbit Flex.
      Ask FixBot
    9. Fitbit Flex Teardown: step 10, image 1 of 3 Fitbit Flex Teardown: step 10, image 2 of 3 Fitbit Flex Teardown: step 10, image 3 of 3
      • Stuck right on to the front of the board we find a near field communications (NFC) antenna.
      • The NFC tag enables a tap launch of the Flex tracker's associated mobile app with "select NFC-enabled Android devices."
      • "It's like magic."
      • This little guy looks like a likely candidate for the NFC controller.
      Ask FixBot
    10. Fitbit Flex Teardown: step 11, image 1 of 2 Fitbit Flex Teardown: step 11, image 2 of 2
      • The motherboard flexes to show us what it's repping:
      • STMicroelectronics 32L151C6 Ultra Low Power ARM Cortex M3 Microcontroller
      • Nordic Semiconductor nRF8001 Bluetooth Low Energy Connectivity IC
      • STMicroelectronics LIS2DH 3-Axis Accelerometer
      • Charger IC: TI BQ24040
      Ask FixBot
    11. Fitbit Flex Teardown: step 12, image 1 of 3 Fitbit Flex Teardown: step 12, image 2 of 3 Fitbit Flex Teardown: step 12, image 3 of 3
      • We just couldn't keep our scalpels to ourselves, so we ripped into the Flex's dongle as well.
      • Plastic aside, we get to the goodies.
      • We quickly free the dongle board from the metal casing of the USB plug.
      Ask FixBot
    12. Fitbit Flex Teardown: step 13, image 1 of 2 Fitbit Flex Teardown: step 13, image 2 of 2
      • Enough loligagging, let's cut to the chase. This diminutive USB board houses all of the hardware needed to communicate with the Flex — and your computer:
      • Texas Instruments CC2540F128 2.4 GHz Bluetooth Low Energy SoC
      • On the contact side:
      • BLE Antenna
      • USB connection contacts
      Ask FixBot
    13. Fitbit Flex Teardown: step 14, image 1 of 2 Fitbit Flex Teardown: step 14, image 2 of 2
      • Fitbit Flex Repairability Score: 2 out of 10 (10 is easiest to repair)
      • Solid waterproofing, no moving parts, and lightweight construction make the Flex a very durable device, with the potential to last a long time.
      • The wrist strap is similarly constructed and can be easily replaced.
      • It's impossible to open the device without destroying it or at least compromising the waterproofing, making internal repairs infeasible.
      • The Flex's inaccessible (and non-replaceable) battery limits the life of the device.
      Ask FixBot
24 Guide Comments
唔,里边似乎不太精致呀。
Jam - Reply Share
i also lost the cable charger, anybody know the 3 pin (positive negative) for fitbit. Any universal charger I can use?
Victor Hugo Garcia Hernandez - Reply Share
look at the enlarged image... Left Pin is connected to the housing of the vibrator - this tells me its GND or Neg, center pin has a much thinner track on the PCB i would call it Data, right pin therefore looks like VCC+.
Sarah - Reply Share
i also lost the cable charger, anybody know the 3 pin (positive negative) for fitbit. Any universal charger I can use and how?
Have you found out? Wish ifixit tore down the motherboard.
Peter - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 91
All Time: 182,973
