This teardown is not a repair guide. To repair your Extech MN36, use our service manual.
  1. Extech Multimeter MN36 Teardown, Remove protective cover: step 1, image 1 of 2 Extech Multimeter MN36 Teardown, Remove protective cover: step 1, image 2 of 2
    • Orange cover provides protection against shocks and better grip
    Ask FixBot
  2. Extech Multimeter MN36 Teardown, Remove back cover: step 2, image 1 of 1
    • Remove two screws to take off back of multimeter
    Ask FixBot
  3. Extech Multimeter MN36 Teardown, Remove fuse and batteries: step 3, image 1 of 1
    • First remove batteries to protect device as you work on it
    • Remove fuse to allow for access to screws
    Ask FixBot
  4. Extech Multimeter MN36 Teardown, Remove circuit board: step 4, image 1 of 2 Extech Multimeter MN36 Teardown, Remove circuit board: step 4, image 2 of 2
    • Remove 4 screws
    • Release clips at top of circuit board
    • Remove circuit board
    Ask FixBot
  5. Extech Multimeter MN36 Teardown, Multimeter case: step 5, image 1 of 3 Extech Multimeter MN36 Teardown, Multimeter case: step 5, image 2 of 3 Extech Multimeter MN36 Teardown, Multimeter case: step 5, image 3 of 3
    • Remove dial
    • Contacts to locate dial position on circuit board
    • Detents to lock in dial position shown removed in last picture
    Ask FixBot
  6. Extech Multimeter MN36 Teardown, Circuit board: step 6, image 1 of 2 Extech Multimeter MN36 Teardown, Circuit board: step 6, image 2 of 2
    • Shown circuit board front and rear
    Ask FixBot
Wieli
2,171 Reputation
13 Guides authored
1 Guide Comment
Aneng DT-9205 multimeter does not work properly
ميمي بيبي - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 32
All Time: 1,064
