This teardown is not a repair guide. To repair your Seagate Expansion, use our service manual.
  1. Expansion Teardown, Open the cover: step 1, image 1 of 1
    • Using a flat head screwdriver or plastic tool
    Ask FixBot
  2. Expansion Teardown: step 2, image 1 of 1
    • Remove the cover
    Ask FixBot
  3. Expansion Teardown: step 3, image 1 of 1
    • Remove the drive from the case
    Ask FixBot
  4. Expansion Teardown: step 4, image 1 of 1
    • Peel back the shielding
    Ask FixBot
  5. Expansion Teardown: step 5, image 1 of 1
    • Remove the Screw with the #02 screw driver
    Ask FixBot
  6. Expansion Teardown: step 6, image 1 of 2 Expansion Teardown: step 6, image 2 of 2
    • Separate the adapter form the sata port
    Ask FixBot
Dan
5,165 Reputation
9 Guides authored
3 Guide Comments
Hello,
I’d like to know if it’s possible to swap in another bigger NAS drive, as I keep my hard drive connected and it might be more durable.
Thank you !
Léana Jiang - Reply Share
This does appear to be a semi-destructive method. In the picture under step 2, you can see the series of plastic brackets on the cover are snapped. See my pictures here
I had difficulty finding a spot to pry up from. There are 4 lips around the cover that should make it easier. See pics.
Derick Roy - Reply Share
Answering a previous comment: yes, it is possible to replace the drive for one of different size. I replaced on of 3TB for one with 4TB and it is working perfectly.
Giovanni Bassi - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 140
All Time: 6,497
