This teardown is not a repair guide. To repair your Dualshock 2, use our service manual.
  1. DualShock 2 Teardown, Removing the Screws: step 1, image 1 of 1
    • On the back of the controller there is screw holes
    • Using a Philip Screw driver remove the screws
    Ask FixBot
  2. DualShock 2 Teardown, Separating the controller pieces: step 2, image 1 of 3 DualShock 2 Teardown, Separating the controller pieces: step 2, image 2 of 3 DualShock 2 Teardown, Separating the controller pieces: step 2, image 3 of 3
    • Using a pry tool separate the two controller pieces
    Ask FixBot
  3. DualShock 2 Teardown, All the buttons: step 3, image 1 of 3 DualShock 2 Teardown, All the buttons: step 3, image 2 of 3 DualShock 2 Teardown, All the buttons: step 3, image 3 of 3
    • First remove the buttons
    • Most of my buttons fell off. Then left up on the sensor and set it aside.
    Ask FixBot
  4. DualShock 2 Teardown, DualShock support: step 4, image 1 of 2 DualShock 2 Teardown, DualShock support: step 4, image 2 of 2
    • When I lifted the controller out of the chassis one of the dual shock motors fell off it soldering. I removed the other one.
    Ask FixBot
  5. DualShock 2 Teardown: step 5, image 1 of 1
    • What you are left with
    Ask FixBot
zachary
825 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 179
All Time: 12,804
