This teardown is not a repair guide. To repair your Christmas tree, use our service manual.
    1. Christmas Tree Teardown, Christmas Tree Teardown: step 1, image 1 of 1
      • The teardown shows a christmas tree Nano, but should you have a bigger - Classic one, you may follow these steps - upscaling everything.
      Ask FixBot
    2. Christmas Tree Teardown: step 2, image 1 of 2 Christmas Tree Teardown: step 2, image 2 of 2
      • First order of business: presents!
      • Use caution and joy when opening your presents.
      Ask FixBot
    3. Christmas Tree Teardown: step 3, image 1 of 2 Christmas Tree Teardown: step 3, image 2 of 2
      • Disconnect the power plug
      • Remove the power socket, should there be one on your tree.
      Ask FixBot
    4. Christmas Tree Teardown: step 4, image 1 of 1
      • To remove the baubles, lift them gently and untangle the string from the branch.
      Ask FixBot
    5. Christmas Tree Teardown: step 5, image 1 of 3 Christmas Tree Teardown: step 5, image 2 of 3 Christmas Tree Teardown: step 5, image 3 of 3
      • If you find a capacitor on your christmas tree, straighten its leads to detach it.
      • All discrete electronic elements should be removed in this manner.
      Ask FixBot
    6. Christmas Tree Teardown: step 6, image 1 of 1
      • Protective hand-wear may come in handy.
      Ask FixBot
    7. Christmas Tree Teardown: step 7, image 1 of 1
      • Remain gentle, even when an element is very difficult to untangle.
      Ask FixBot
    8. Christmas Tree Teardown: step 8, image 1 of 2 Christmas Tree Teardown: step 8, image 2 of 2
      • To remove the top ornament, lift it upwards.
      Ask FixBot
    9. Christmas Tree Teardown: step 9, image 1 of 1
      • Finally, remove the lights.
      • Begin with the light that was placed as the last. If you are uncertain, start from the topmost one.
      Ask FixBot
    10. Christmas Tree Teardown: step 10, image 1 of 2 Christmas Tree Teardown: step 10, image 2 of 2
      • Before you run around barefoot in celebration, clean up.
      • Check amongst the floor sweepings for any surface mount components components which may have gone missing during assembly, and carefully put them aside
      • The christmas tree is disassembled!
      • Check whether your local council will take your old Christmas tree for recycling. Burning is not recommended on account of the CO2 emissions it would produce.
      • Thank you for reading, hope you are having a happy holiday.
      • Fix yourself a wonderful New Year in 2025!
      Ask FixBot
baq
305 Reputation
3 Guides authored
1 Guide Comment
skuirel sed it good!
Kyle Wiens - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 34
All Time: 9,409
