This teardown is not a repair guide. To repair your bread maker, use our service manual.
    1. Bread Maker Teardown, Bread Maker teardown: step 1, image 1 of 1
      • The Toast Select Luxe adjusts the toasting time for each type of bread. 'Lift & Look' to check if it's done. Press 'A Bit More' and to give it just that… a little bit more. Follow toasting progress with the LED countdown indicator. Crafted with brushed stainless steel in premium metallic finishes and chrome accents.
      • VARIABLE BROWNING CONTROL Toast to your ideal browness level while the LED indicates your browning progress.
      • INNOVATIVE AUTO FEATURES 1-Touch 'A Bit More' and 'Lift & Look' functions are derived directly from your feedback and makes for flawless toasting.
      • EASY CLEANING No need to ever lift when cleaning. Just pull out the front crumb tray and tip it into the dustbin.
      • Construction Materials:Brushed stainless steel body with back-lit buttons.
      • Dimensions (WxDxH):8.2" x 7.9" x 13.4"
      • Power:1000 Watts Voltage:120Volts, 60Hz Settings:6 Bread Settings: Wholewheat, White, Bagel, Waffles, Pastries and English Muffins 4 Functions: 'Lift & Look', 'A Bit More'/Reheat, Frozen and Cancel
      Ask FixBot
    2. Bread Maker Teardown, Remove the screws: step 2, image 1 of 2 Bread Maker Teardown, Remove the screws: step 2, image 2 of 2
      • From the bottom, the bread maker has 4 screws securing two pieces of the shell.
      • Time to cut it open!First thing’s first, let’s turn over the machine, there are 4 screw in sight, therefore a screw driver is up.
      • Take a closer look after removing the screws on the bottom, we can see there are still 4 plastic pads and silicon circles that are waiting to be taken away.
      Ask FixBot
    3. Bread Maker Teardown: step 3, image 1 of 2 Bread Maker Teardown: step 3, image 2 of 2
      • You might notice that the shells are not apart yet, but take a closer look, it’s already loose.
      • This is when you flip it upside-down again, find the very botton on the side and take it off, a simple twist and pull will do the work.
      Ask FixBot
    4. Bread Maker Teardown: step 4, image 1 of 3 Bread Maker Teardown: step 4, image 2 of 3 Bread Maker Teardown: step 4, image 3 of 3
      • Time to get our first glimpse inside this bread maker.
      • To take off the mainboard, you need a screw driver to remove those three screws.
      • Unplug those wires highlighted in the photo.
      • Ta-da! You successfully removed the mainboard!
      Ask FixBot
    5. Bread Maker Teardown: step 5, image 1 of 3 Bread Maker Teardown: step 5, image 2 of 3 Bread Maker Teardown: step 5, image 3 of 3
      • To teardown the mainboard from the other side, this is what you have to do--
      • Unplug all wires connected to it.
      • picture 2 shows how it should be like after you did the instruction above.
      • All you have to do now, is to take away the mainboard along with the metal chip beneath it.
      Ask FixBot
    6. Bread Maker Teardown: step 6, image 1 of 1
      • This is the last step of taking the shell apart--cut the wire.
      Ask FixBot
    7. Bread Maker Teardown, dismiss the disk: step 7, image 1 of 3 Bread Maker Teardown, dismiss the disk: step 7, image 2 of 3 Bread Maker Teardown, dismiss the disk: step 7, image 3 of 3
      • First, take off the screws like shown in the picture.
      • Then you will see a board also secured with screws——repeat your last move.
      • There you have a small board!
      Ask FixBot
    8. Bread Maker Teardown: step 8, image 1 of 2 Bread Maker Teardown: step 8, image 2 of 2
      • Same spot, same move—— remove three screws on top of the disc.
      • Then there you are—— a small disc!
      Ask FixBot
    9. Bread Maker Teardown: step 9, image 1 of 2 Bread Maker Teardown: step 9, image 2 of 2
      • Let's move on to the inside of the shell, shall we?
      • There are so many screws on this thing, huh? Let's just screw them off and take out the small board.
      Ask FixBot
    10. Bread Maker Teardown: step 10, image 1 of 2 Bread Maker Teardown: step 10, image 2 of 2
      • Same old same old. Screw them off and take out the transparent plastic lid.
      Ask FixBot
    11. Bread Maker Teardown: step 11, image 1 of 2 Bread Maker Teardown: step 11, image 2 of 2
      • bend the metal sheets shown in the picture.
      • Then you will have those small components.
      Ask FixBot
    12. Bread Maker Teardown: step 12, image 1 of 2 Bread Maker Teardown: step 12, image 2 of 2
      • Unbend the sheet metal in p1&2.
      Ask FixBot
    13. Bread Maker Teardown: step 13, image 1 of 3 Bread Maker Teardown: step 13, image 2 of 3 Bread Maker Teardown: step 13, image 3 of 3
      • Next, take off the clips in p1&2.
      • Generated by all the steps above, you can pull out this metal wire easily.
      Ask FixBot
    14. Bread Maker Teardown: step 14, image 1 of 1
      • However, the last step is a lot more difficult, this is to seperate its silver machine case with its black plastic base.
      • This step requires specialised tool, for any other normally seen screw drivers/tools will easily bend the metal inside.
      • Therefore, if not necessary, don't teardown this part without specialised tools.
      Ask FixBot
    15. Bread Maker Teardown: step 15, image 1 of 1
      • All components of a bread maker.
      Ask FixBot
Diana S
241 Reputation
1 Guide authored
1 Guide Comment
Je ne sais pas de quelle origine vient l'appellation "Machine à pain" pour cet appareil, mais en France on appelle cela un grille-pain. L'appellation "Machine à pain" est destinée à un appareil qui permet de pétrir et cuire le pain ce qui est franchement différent.
Gilles Guérin - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 65
All Time: 961
