Introduction
Go to step 1 ↓
This hand-me-down baby monitor has a busted volume/on-off switch. Monitor only operates while pressing down on the volume dial. If you think I have the energy to hold down that dial while trying to sleep, you got another thing coming. Baby crying... gotta go.
Tools
This teardown is not a repair guide. To repair your Baby Monitor , use our service manual.
    1. Baby Monitor  Teardown, Teardown: step 1, image 1 of 3 Baby Monitor  Teardown, Teardown: step 1, image 2 of 3 Baby Monitor  Teardown, Teardown: step 1, image 3 of 3
      Tool used on this step:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      Buy
      • Here is the baby monitor in all its glory.
      • Start by turning the device speaker-side down.
      • Remove the flathead screw securing the battery cover using a flathead screwdriver.
      • Remove the battery cover after fully disengaging the screw.
      Ask FixBot
    2. Baby Monitor  Teardown: step 2, image 1 of 3 Baby Monitor  Teardown: step 2, image 2 of 3 Baby Monitor  Teardown: step 2, image 3 of 3
      Phillips #1 Screwdriver
      $5.49
      Buy
      • Remove the batteries from the compartment.
      • Remove the five phillips screw holding the casing together using a phillips #1 screwdriver.
      • The fifth screw is hidden beneath the battery cover, toward the center of the monitor and is recessed deep into the casing.
      Ask FixBot
    3. Baby Monitor  Teardown: step 3, image 1 of 3 Baby Monitor  Teardown: step 3, image 2 of 3 Baby Monitor  Teardown: step 3, image 3 of 3
      • CAUTION: Do not yank the casing apart!!!
      • Gently pry from the bottom and work a finger along the side and until monitor pops in half.
      • The speaker cabling is soldered to the main board and the speaker is stuck in the front casing with adhesive.
      • Lay the two halves as shown.
      Ask FixBot
    4. Baby Monitor  Teardown: step 4, image 1 of 1
      • Remove the two screws securing the main board.
      Ask FixBot
    5. Baby Monitor  Teardown: step 5, image 1 of 2 Baby Monitor  Teardown: step 5, image 2 of 2
      Spudger
      $3.99
      Buy
      • Pry lightly around the edge of the main board between the board and the casing to help free the board. Fingernails, a spudger, or plastic opening tools can be used for this task.
      • DO NOT TRY TO REMOVE THE MAIN BOARD COMPLETELY!!! There are soldered items that need to be dealt with. Follow along closely.
      • Gently, and I mean gently, pull up on the LED assembly to loosen the main board from the rear casing.
      • Any resistance should indicate that the board needs to be loosened from the casing, around the edges, more before proceeding.
      Ask FixBot
    6. Baby Monitor  Teardown: step 6, image 1 of 1
      • PROCEED WITH CAUTION!!! The antenna cable and the battery contacts are soldered onto the board.
      • Your monitor should look like this, with a small gap between the main board and the rear casing.
      • The next step will merely free the volume control dial from the casing and NOT free the main board from the casing.
      • To remove the main board from the casing, you MUST desolder the antenna cable and two battery contacts from the board.
      Ask FixBot
    7. Baby Monitor  Teardown: step 7, image 1 of 3 Baby Monitor  Teardown: step 7, image 2 of 3 Baby Monitor  Teardown: step 7, image 3 of 3
      • Create about a 30 degree angle between the rear casing and your workspace, lifting the casing by the top end. I used 3 decks of playing cards to prop up the casing from my workspace.
      • Lift the main board from the rear casing at the bottom, making sure the volume dial clears the screw retainer post. DO NOT COMPLETELY REMOVE MAIN BOARD!
      • Once free, set the main board back down on the casing.
      • You are now free to desolder any of the contacts that need repair. In my situation, I will be examining the volume dial and will not need to desolder.
      • Good luck!
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 28
Past 30 Days: 90
All Time: 10,047
