Introduction
Go to step 1 ↓This page lists chip ID information for Apple's HomeView.
Video Overview
Apple APL1V08/339S01617 A18 hexa-core applications processor w/ GPU layered under a SK hynix H58G66BK8HX153 8 GB LPDDR5X SDRAM memory
Apple APL109A/338S01169 power management
Analog Devices MAX98397 mono class-DG audio amplifier
Likely Infineon CYUSB2408 USB level shifter
Likely Texas Instruments TPS65709 camera power management
Texas Instruments TPS62827 adjustable 4 A step-down converter
Texas Instruments INA190A2 current sense amplifier
Texas Instruments INA191A2 current sense amplifier
Texas Instruments TLV9001 single operational amplifier
Texas Instruments TLV75512P 1.2 V, 500 mA low-dropout regulator
Texas Instruments LP5907YKGR-2.85 2.85 V, 250 mA low-dropout regulator
Nexperia 74AUP1G06 single inverter
Texas Instruments SN74AXC2T45 2-bit translating transceiver
Texas Instruments LSF0101 single bidirectional multi-voltage level translator
Kioxia K5A2 64 GB NAND flash memory
Texas Instruments SN2012027 USB Type-C port controller
Winbond W25Q80DV 1 MB serial NOR flash memory
Texas Instruments LP8548B1-09 LED backlight driver
Likely Renesas iW7042P-13 LED backlighting driver
Texas Instruments TPS65132T6 single inductor, dual output DC-DC converter
Renesas SLG46108 programmable mixed-signal matrix
Texas Instruments LM62460 6 A buck converter
Texas Instruments TPS62821 1 A step-down converter
SG Micro SGM66099C-ADJ adjustable synchronous boost converter
Texas Instruments TLV7041 single comparator
Texas Instruments LP5907UVx-3.3 3.3 V, 250 mA low-dropout regulator
Texas Instruments DAC53401 10-bit digital-to-analog converter
Texas Instruments INA191A4 current sense amplifier
Texas Instruments TPS55340 5 A boost converter
Texas Instruments TPS62932 2 A synchronous buck converter
Texas Instruments LP5907UVx-1.8 1.8 V, 250 mA low-dropout regulator
Texas Instruments TLV70733P 3.3 V, 200 mA low-dropout regulator
Texas Instruments SN74LVC1G14 single Schmitt-trigger inverter
Alpha & Omega Semiconductor AONR21395C MOSFET
