My Problem
My copper electric kettle stopped heating up after about 18 months of use. The root cause was a burnt-out heating element, heavily damaged by limescale buildup from local hard water. Instead of throwing it away and buying a replacement, I decided to fix it myself.
My Fix
I followed some online repair guides and managed to get it working again in under an hour:
Safety First: Unplugged the kettle completely.
Disassembly: Removed the screws from the base and carefully disconnected the internal wires.
Deep Cleaning: Descaled the inside to remove all the accumulated mineral deposits.
Part Replacement: Swapped out the dead part for a new 1500W heating element.
Reassembly: Put everything back together and polished the copper exterior.
My Advice
This repair was a great "aha" moment in the kitchen. Here is how to prevent this issue from happening again:
Descale Monthly: Limescale from hard water kills heating elements fast. Mix vinegar and water (1:1 ratio), boil it twice, and rinse.
Post-Repair Check: Boil a little vinegar after reassembling. A clean smell confirms there is no unwanted residue left inside.
Future-Proofing: Use filtered water daily to stop limescale from building up in the first place.
2 Comments
okay it is very useful
The Falls at Blue Ridge - Reply Share
Great Job! This was very useful
Octavia Polk - Reply Share
