« Back to All Stories
Easy but beware of battery pull-tab adhesive
Jonathan Schwalm -
iPhone 6
Story image
iPhone 6 Battery Replacement
45 minutes
Moderate
My Problem
My battery was not working well and phone was slow.
My Fix
I could probably do it in under a half hour and rate it easy if it weren’t for the pull-tabs. The first one worked, and the second broke halfway through. That took an extra 15 minutes to push the adhesive into a place I could grab it to complete the repair. The replacement battery is perfect and SOOOO much better than the 3-year-old one; the phone works like new! Time will tell for how long it lasts but so far so good.
My Advice
Be care with the pull tabs.
iPhone 6 Battery Image
iPhone 6 Battery
$29.99
1 Comment
If you pry up the battery a bit you can pull out the adhesive strips from the edge of the battery, between the frame and the battery. I tip is to heat the back side on the phone with a heat gun, soft strips do not snaps off that easy.
peter - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 136
