« Back to All Stories
2013 unibody MBP battery replacement
Ian Smythe -
MacBook Pro 15" Retina Display Mid 2012
Story image
MacBook Pro 15" Retina Display Mid 2012 Battery Replacement
2 hours
Moderate
My Problem
After approx. 600 cycles, diagnostics on the battery indicated one of the cells was bad, generating a service battery notification. Apple Store wanted $200+ to basically replace the top case assembly and battery, plus wanted to keep my work MBP for a week.
My Fix
Repair went exactly per the guide, no problems at all.
My Advice
Take your time. Don't try to force anything. ALWAYS label parts and take photos on removal. Be judicious with the acetone in removing the battery adhesive, no need to flood it. Also no need to wait the 2-3 minutes per the guide; 30 sec to a minute is enough. Photo in place or label aircard antennas prior to disconnect to ensure you reinstall to the correct contact heads.
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery Image
$89.99
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 401
