« Back to All Stories
Fan Replacement
ctjewett -
MacBook Air 11" Mid 2011
Story image
MacBook Air 11" Mid 2011 Fan Replacement
15 minutes
Moderate
My Problem
Old fan was making all sorts of noise. I didn't even realize my Mac had a fan for years until this fan started to go, and then it was obvious as a blue sky.
My Fix
Overall, it was a pretty easy repair, but a tad trickier than a standard PC laptop due to the tight tolerances and incredibly small parts. If you can put the Mac in a shallow box so no screws get lost in the process, it'll probably help considerably.
My Advice
The only super tricky part was sliding the new fan's ribbon cable into the slot. I used the spudger and pushed on the only small crease I could find to slide it into the slot. I suggest powering it on while still apart to verify functionality, then power it off and finish stitching everything back together.
MacBook Air 11" (Mid 2011-Early 2015) Fan Image
$19.99
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 124
