« Back to All Stories
Ipod classic gen 3
Andrew O'Brien -
iPod 3rd Generation
Story image
  • Image #1
  • Image #2
  • Image #3
iPod 3rd Generation Battery Replacement
30 minutes
Moderate
My Problem
my ipod would not charge, turn on, or hold a charge. Whenever it was plugged in, the iPod would display the apple logo then flash off. The battery was bad.
My Fix
I recieved the battery replacement kit one day early, and got right to work. Popping apart the iPod was the hardest part of the whole repair, with not breaking the hard drive ribbon cable as a very close second. Removing the battery and placing the new battery was quite easy, and routing the cable so it would pop back together was easy enough. After replacing the battery, I was able to breathe new life into an otherwise fancy paperweight.
My Advice
be very careful popping apart the case, because the lock switch assembly and headphone jack can be ripped from the internal logic board and wreak havoc to that board. bottom first, then work around to the top. CAREFULLY.
iPod 3G Battery Image
iPod 3G Battery
$13.99
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 193
