why! WDi7SSD fan replacement
    1. why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: step 1, image 1 of 3 why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: step 1, image 2 of 3 why! WDi7SSD fan replacement, why! WDi7SSD Opening procedure: step 1, image 3 of 3
      • Make sure the computer is disconnected from the power source.
      • Flip the computer over.
      • Remove the six screws with a 2 mm Allen key.
      • Carefully remove the back panel, as well the left and right panel.
      Ask FixBot
    2. why! WDi7SSD fan replacement: step 2, image 1 of 1
      • Now flip up the base panel to which all components are attached.
      Ask FixBot
    1. why! WDi7SSD fan replacement, Fan: step 3, image 1 of 2 why! WDi7SSD fan replacement, Fan: step 3, image 2 of 2
      • Remove the two Phillips PH2 screws on the fan.
      Ask FixBot
    2. why! WDi7SSD fan replacement: step 4, image 1 of 2 why! WDi7SSD fan replacement: step 4, image 2 of 2
      • Remove the cable connecting the front part (with the LEDs) to the power source.
      • Remove that part of the case and its cable.
      Ask FixBot
    3. why! WDi7SSD fan replacement: step 5, image 1 of 3 why! WDi7SSD fan replacement: step 5, image 2 of 3 why! WDi7SSD fan replacement: step 5, image 3 of 3
      • Remove the four screws on the heat sink with a Phillips PH2 screwdriver.
      • Remove the heat sink.
      Ask FixBot
    4. why! WDi7SSD fan replacement: step 6, image 1 of 2 why! WDi7SSD fan replacement: step 6, image 2 of 2
      • Carefully remove the fan together with its case.
      • Carefully remove the connector connecting the fan to the power source.
      Ask FixBot
In order to reassemble your device, follow the steps of this guide in reverse order.
Special thanks to these translators:
de en
100%
Maria Parker is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 56
All Time: 545
