Up to 20% off select tools
why! WDi7SSD Replace processor (CPU)
View statistics:
Past 24 Hours:
2
Past 7 Days:
8
Past 30 Days:
64
All Time:
573
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow these instructions to replace the processor (CPU) with an Intel i7 3770S processor or a more powerful processor.
    1. why! WDi7SSD Replace processor (CPU), why! WDi7SSD Opening procedure: step 1, image 1 of 3 why! WDi7SSD Replace processor (CPU), why! WDi7SSD Opening procedure: step 1, image 2 of 3 why! WDi7SSD Replace processor (CPU), why! WDi7SSD Opening procedure: step 1, image 3 of 3
      • Make sure the computer is disconnected from the power source.
      • Flip the computer over.
      • Remove the six screws with a 2 mm Allen key.
      • Carefully remove the back panel, as well the left and right panel.
      Ask FixBot
    2. why! WDi7SSD Replace processor (CPU): step 2, image 1 of 1
      • Now flip up the base panel to which all components are attached.
      Ask FixBot
    1. why! WDi7SSD Replace processor (CPU), Processor (CPU): step 3, image 1 of 3 why! WDi7SSD Replace processor (CPU), Processor (CPU): step 3, image 2 of 3 why! WDi7SSD Replace processor (CPU), Processor (CPU): step 3, image 3 of 3
      • Loosen the 4 PH2 Phillips screws of the heat sink.
      • Now remove the heat sink.
      Ask FixBot
    2. why! WDi7SSD Replace processor (CPU): step 4, image 1 of 2 why! WDi7SSD Replace processor (CPU): step 4, image 2 of 2
      • Use the screwdriver to unscrew the three PH2 slotted screws to release the CPU holder.
      • Press down the spring on the right side of the CPU and pull it carefully to the side.
      • Put the CPU aside.
      • To remove the thermal paste, you can use isopropanol. The thermal paste must be completely removed from the heatsink and CPU.
      Ask FixBot
To reassemble the unit, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Felice Suglia
33,655 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 64
All Time: 573
