This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
why! W670SZQ1 Processor Replacement
    1. why! W670SZQ1 Processor Replacement, The Batteries: step 1, image 1 of 3 why! W670SZQ1 Processor Replacement, The Batteries: step 1, image 2 of 3 why! W670SZQ1 Processor Replacement, The Batteries: step 1, image 3 of 3
      • Unlock the lock latch on the left.
      • Unlock the lock latch on the right.
      • Remove the battery while holding the lock latch unlocked.
      Ask FixBot
    1. why! W670SZQ1 Processor Replacement, Access to Major Components: step 2, image 1 of 3 why! W670SZQ1 Processor Replacement, Access to Major Components: step 2, image 2 of 3 why! W670SZQ1 Processor Replacement, Access to Major Components: step 2, image 3 of 3
      • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
      • Lift the bottom right cover with the iFixit Opening Tool.
      • Lift the lower left cover with the iFixit Opening Tool.
      • Finally clear the bottom cover completely to access the main components.
      Ask FixBot
    1. why! W670SZQ1 Processor Replacement, The processor: step 3, image 1 of 3 why! W670SZQ1 Processor Replacement, The processor: step 3, image 2 of 3 why! W670SZQ1 Processor Replacement, The processor: step 3, image 3 of 3
      • Using the Phillips screwdriver, unscrew the 4 screws holding the processor cooling radiator.
      • Remove the cooling radiator. Once the radiator removed you can see the processor with its locking latch.
      • Now unlock the processor with a small screwdriver. Then remove it gently.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Israel is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 94
All Time: 502
